replacing factory steering wheel w/ airbag
Old Apr 24, 2005 | 12:04 PM
cdfive.'s Avatar
Default replacing factory steering wheel w/ airbag
im thinking of replacing the steering wheel in my 96 accord since i have a momo steering wheel and hub just sitting here. is there a way of bypassing the SRS light so that it isnt constantly on? can i put a resistor in the SRS connector to make it think that the connection still exists?
any help is appreciated. thanks.
Old Apr 24, 2005 | 12:37 PM
Drag-Accord's Avatar
Default Re: replacing factory steering wheel w/ airbag (cdfive)
If you are going this far, and are 100% sure about removing the air bag for good. Then you can do what i did. I just pulled my gauge cluster out and broke the little bulb that illuminates the SRS light. A screw driver works great for that i also did this with the ABS light and the Seatbelt light.
Old Apr 24, 2005 | 01:20 PM
cdfive.'s Avatar
Default Re: replacing factory steering wheel w/ airbag (Drag-Accord)
lol, i didnt really want to go that route, maybe pull the cluster and add some tape over the SRS light.
Old Apr 24, 2005 | 02:00 PM
Well i suppose if you ever plan on taking the car back to stock, or try to sell it. Being able to put the airbag back in is a good thing when you try to sell a car.
Old Apr 24, 2005 | 02:09 PM
puma1077's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag-Accord &raquo;</TD></TR><TR><TD CLASS="quote">If you are going this far, and are 100% sure about removing the air bag for good. Then you can do what i did. I just pulled my gauge cluster out and broke the little bulb that illuminates the SRS light. A screw driver works great for that i also did this with the ABS light and the Seatbelt light. </TD></TR></TABLE>
why did u brake the light? why didnt u just pull it out
Old Apr 24, 2005 | 02:55 PM
iam7head's Avatar
Default Re: replacing factory steering wheel w/ airbag (puma1077)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by puma1077 &raquo;</TD></TR><TR><TD CLASS="quote">why did u brake the light? why didnt u just pull it out</TD></TR></TABLE>
good question indeed, just for your info the new honda cluster use non-removable LED for most of the warning light but i don't think that's the case for 5th gen accord.
you can just take out the blub or ignore it, not much people from what i know will go that far(meaning fooling the srs system with some kind of bypass voltage) since you are talking about a couple thousand dollar worth of electronic and circuit.
Old Apr 24, 2005 | 04:09 PM
cuz i'm lazy like that
I have a 4th gen and by the looks of it, it would have been pretty hard to pull the bulb out w/o breaking it. It sits pretty deep inside there. but if i had patience and wanted to salvage the little bulb i'm sure i could have found a way.
Old Apr 25, 2005 | 06:12 AM
cdfive.'s Avatar
anyone else know if a resistor can be put in the SRS connector to make it seem like theres still a connection in place?
Old Apr 25, 2005 | 05:57 PM
fuglycord's Avatar
safety first...an airbag can save your life
bmxpunk
Jul 29, 2008 07:28 PM
lamboextreme
10
Sep 24, 2007 06:09 PM
Rene M
Oct 11, 2006 02:43 PM
mikehawkBUiLT
36
Aug 21, 2004 09:55 PM
