What tire size do I need?
Old Apr 24, 2005 | 11:16 AM
ToxicBug's Avatar
Default What tire size do I need?
I have a 2000 EK hatch and currently its on 185/65R14 winter tires. I bought 15" 16 spoke integra rims and I'm wondering what sized tires do I need now, so it would fit as well as my current tires do. I calculated something like 205/55R15, is that right?
Old Apr 24, 2005 | 11:46 AM
Kyles ej1's Avatar
Default Re: What tire size do I need? (ToxicBug)
205/50s
Old Apr 24, 2005 | 11:51 AM
derspi's Avatar
Probably better off with something like 195/55R15 if they're stock rims. Wheel width is probably 6.5" or less so 205 might be a tad too wide.
Old Apr 24, 2005 | 11:52 AM
Kyles ej1's Avatar
Default Re: (derspi)
did u buy the ls mesh rims? if so 205's are fine
Old Apr 24, 2005 | 02:46 PM
ToxicBug's Avatar
I got these:
Old Apr 24, 2005 | 02:49 PM
DavidT or VajT's Avatar
Default Re: What tire size do I need? (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">205/50s</TD></TR></TABLE>
Old Apr 24, 2005 | 02:55 PM
.:Swig:.'s Avatar
Default Re: What tire size do I need? (DavidT or VajT)
205/50/15
Old Apr 24, 2005 | 07:20 PM
AL ASPIRATED's Avatar
Default Re: What tire size do I need? (00mofo)
205-50-15 or 195-55-15
either or works, but u can drop it more on 195-55-15 and has a less chance of rubbing
but watever u decide on both works
Old Apr 25, 2005 | 07:16 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: What tire size do I need? (AL ASPIRATED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AL ASPIRATED &raquo;</TD></TR><TR><TD CLASS="quote">205-50-15 or 195-55-15
either or works, but u can drop it more on 195-55-15 and has a less chance of rubbing</TD></TR></TABLE>
Another advantage of the 195/55-15 is that it will keep the accuracy of your speedometer and odometer. With the 205/50-15, both will read 1.7 percent higher than actual as a result of the tire size.
I would get 195/55-15 if the tires you're considering are available in that size, otherwise 205/50-15. There are quite a few good tires available in 195/55-15, including Yokohama AVS ES100 ($61), Avon Tech M500 ($72), and, if you are willing to spend a lot more money for a grippy, great-handling tire, Bridgestone Potenza RE010 ($134).
Old Apr 26, 2005 | 04:56 PM
derspi's Avatar
Default Re: What tire size do I need? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
I'm thinking of going back to 195/55R15 after having 205/50R15 for the last 2 summers on the stock Si rims. Seemed to have lost some steering feel with the wider 205 tires - do you think the 205s were too wide for the stock Si rims? I've been reading up on tires as well but the Avon Tech M500s are so new, I haven't found any test info. on them other than the stuff posted up at TireRack. You have any opinion or know of any owners experience with the Avons?
Old Apr 27, 2005 | 06:55 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: What tire size do I need? (derspi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derspi &raquo;</TD></TR><TR><TD CLASS="quote">do you think the 205s were too wide for the stock Si rims?</TD></TR></TABLE>
Not necessarily, but I don't think they necessarily offer any big advantages over the 195. (It depends on the specific tire, and the wheel width.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derspi &raquo;</TD></TR><TR><TD CLASS="quote">I've been reading up on tires as well but the Avon Tech M500s are so new, I haven't found any test info. on them other than the stuff posted up at TireRack. You have any opinion or know of any owners experience with the Avons?</TD></TR></TABLE>
Nope. I'm in the same boat - they did well in Tire Rack testing, haven't heard from anyone about actual experience.
actek23
Jan 8, 2008 05:48 PM
Wazup
Jan 3, 2008 09:50 AM
808State
Jan 30, 2005 12:48 AM
90Integra
Oct 30, 2004 06:05 PM
zither
Jun 22, 2002 08:14 AM
