possible injector problem a6-z6
Old Apr 24, 2005 | 09:49 AM
mr. carpenter's Avatar
Default possible injector problem a6-z6
i swapped to obd1 injectors when i did my swap. i cut the wires at the resistor and soldered them together. has anyone had any trouble doing it like this? i'm getting hesitation right after shifting and the car seems to hit a rev limiter at 5-6k in every gear. i saw where eda6 has mentioned a block off plug. where can this be obtained or can i make one? i'm about ready to go back to the a6 injectors.
https://honda-tech.com/zerothread?id=1222701
this thread has a little more detail.
Old Apr 26, 2005 | 07:28 PM
Default Re: possible injector problem a6-z6 (mr. carpenter)
ttt
Old Apr 28, 2005 | 04:34 PM
top
Old Apr 28, 2005 | 05:35 PM
eda6's Avatar
If you've soldered the wires together then you've already made one.
You can find these near the drivers side shock tower in eg's\eh's.
Think of this as a distribution block.
I'd get a ohmmeter and check resistance from where you soldered the wires together to the injector clips if you think your wiring is shitty. All readings should be similar. Check the resistance of the coils. You should see 10-13 ohms.
If it's electrically ok then i'd try another set of injectors.
Old Apr 30, 2005 | 03:37 PM
Default Re: possible injector problem a6-z6 (eda6)
wnet and checked resistance on the injectors and they all read zero. tried to put hte a6 injectors back in and ressistor box and car still does the same thing. runs fine until it hits 5k then it just acts like it's bouncing off the limiter.
goldex420
Sep 6, 2013 10:32 PM
Timmah!!
May 20, 2003 07:47 PM
spun Vtec
10
May 12, 2003 06:21 PM
digglewitz
Dec 11, 2002 11:11 PM
EGHatchy
Jul 13, 2002 08:53 AM
