Need help with vibration problem.
Old Apr 24, 2005 | 07:47 AM
ALLmoTorB18CrX's Avatar
Default Need help with vibration problem.
I have a 90 CRX w/B18C and recently I have been having a hard vibration when the car gets above 3000 RPM. At first it was just the Front Passenger side that was doing it. I raised the car on a lift, took the tires off and it still did the same thing. I replaced the axles and it still did the same thing. Last night I swapped the transmission because it was grinding in 2nd gear and when I put it on the lift again the Front passenger side is fine and now it vibrates on the front drivers side! Any help would be greatly appreciated. Thanks in advance.
Old Apr 24, 2005 | 12:32 PM
killerbseries's Avatar
I would check all your motor mounts first...my bro has the same problem..do you feel it in the wheel??
BoltonGSR
Apr 3, 2009 06:15 AM
imsebtactular
Nov 16, 2007 10:28 PM
SGVridgerunner
Dec 21, 2005 08:41 PM
DarkCyde SI
May 23, 2003 10:33 PM
slowassR
Sep 24, 2002 12:48 PM
