Check engine light........
Old Apr 24, 2005 | 05:41 AM
djdelirius's Avatar
Default Check engine light........
I've got a 99 Honda Accord EX V6 and the check engine light is on. Is there anyway to turn it off without taking it into the honda shop?
Old Apr 24, 2005 | 10:41 AM
Schmitey's Avatar
Default Re: Check engine light........ (djdelirius)
well...most people try to find out what caused the problem first
I'm pretty sure you could find your answer after about 30 seconds of searching. Even more most auto parts stores will even scan and erase the codes for you for free.
Old Apr 24, 2005 | 10:56 AM
Mod Express's Avatar
check engine light = problem. you fix problems. haha
Old Apr 24, 2005 | 05:03 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djdelirius &raquo;</TD></TR><TR><TD CLASS="quote">I've got a 99 Honda Accord EX V6 and the check engine light is on. Is there anyway to turn it off without taking it into the honda shop?</TD></TR></TABLE>
Whenever the CEL is on, it indicates your car has problem(s). Even if you turn the light off without fixing the problem, the problem is still there, so what is the point? Well if you want to turn it off, take out negative ternimal of the battery for lil bit then put it back on (make sure you have the code for radio if you still using stock radio). Or you could pull out 7.5 radio fuse and put it back on after lil bit.
Old Apr 24, 2005 | 06:34 PM
Si12iuS's Avatar
Theres is a likely chance that when you do turn your check engine light without fixing the problem. After the ecm runs tests and go through different loads the light will just probably comeon again or u might be lucky and it is just intermittent.
Old Apr 24, 2005 | 10:59 PM
philadd's Avatar
Default Re: Check engine light........ (xbn83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">
Whenever the CEL is on, it indicates your car has problem(s). Even if you turn the light off without fixing the problem, the problem is still there, so what is the point? Well if you want to turn it off, take out negative ternimal of the battery for lil bit then put it back on (make sure you have the code for radio if you still using stock radio). Or you could pull out 7.5 radio fuse and put it back on after lil bit.</TD></TR></TABLE>
It's not the radio fuse in 6th gens. It's the Clock Back-up fuse.
kenchidi
Transmission & Drivetrain
Dec 22, 2014 02:14 AM
hondagall10
Aug 21, 2010 07:08 PM
B16Jacques
May 13, 2006 09:32 AM
nguyennhatquang
Jun 15, 2005 06:50 PM
pang07
Jan 7, 2005 05:12 PM
