New injectors/pump/exhaust & tuning??
Old Apr 24, 2005 | 04:28 AM
Integra21's Avatar
Default New injectors/pump/exhaust & tuning??
how difficult is the install of the injectors and pump?
also, i will be adding a test pipe and 3" thermal at the same time. i will be getting the car street tuned afterwards to add fuel etc..
would i be able to install the fuel pump/injectors/test pipe and exhaust at my house, then would i be able to drive (in vaccum) to get it tuned? i wouldnt be running TOO rich with the 550cc's or anything
THANKS
Old Apr 24, 2005 | 07:18 AM
Integra21's Avatar
Default Re: New injectors/pump/exhaust & tuning?? (Integra21)
c'mon guys i need to purchase the injectors and pump soon
Old Apr 24, 2005 | 07:54 AM
11psiTurboSI's Avatar
Walbro fuel pump is a direct fit and its located right under the rear seats. Injectors are just as easy, but you will need obd 1 clips if you 96+ and if there not saturated injectors you will also need a resistor box. What are you going to be using for management?
Old Apr 24, 2005 | 08:41 AM
Integra21's Avatar
Default Re: New injectors/pump/exhaust & tuning?? (11psiTurboSI)
I have greddy 310cc injectors on my 98 gsr so im assuming ill need the odb1 clips.
for management i have hondata s200b
any other suggestions?
also with the 550ccs and pump installed, would i be able to drive about 30min in vaccum to get it tuned?
thanks for the response
Old Apr 24, 2005 | 09:13 AM
PHiZ's Avatar
You'll most likely need a new chip to get those 550s to idle the car, and be able to drive it.
-PHiZ
Old Apr 24, 2005 | 10:28 AM
Integra21's Avatar
Default Re: New injectors/pump/exhaust & tuning?? (PHiZ)
a new chip?? elaborate?
would i have to install them right before i get it tuned? like while im there...?
Old Apr 24, 2005 | 11:13 AM
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">a new chip?? elaborate?
would i have to install them right before i get it tuned? like while im there...?</TD></TR></TABLE>
Wow. A hondata chip, scaled for 550cc injectors.
-PHiZ
Old Apr 24, 2005 | 11:20 AM
Treblarefils's Avatar
Yeah car will most likely not run unless you can get the injectors scaled right..
Old Apr 24, 2005 | 01:32 PM
Integra21's Avatar
Default Re: New injectors/pump/exhaust & tuning?? (Treblarefils)
well i have hondata already so looks like ill have to have the tuner scale the injectors before tuning
umair
Nov 29, 2007 11:49 AM
deucedeuceEK
Jun 2, 2007 04:33 AM
h22acivicman
Apr 6, 2004 08:00 PM
johnzm
Jan 25, 2004 07:34 PM
turbo Si
Jun 7, 2002 04:59 AM
