best 2.1 all motor cams?
Old Apr 24, 2005 | 12:24 AM
JBBNJ609's Avatar
Default best 2.1 all motor cams?
whats the best for good power, the best i can buy ?? 2.1 with about 12.5:1 cr or alittle less
thanks
Old Apr 24, 2005 | 08:22 AM
JBBNJ609's Avatar
Default Re: best 2.1 all motor cams? (jason bouchard)
bump, im looking at alot of ones, but i do want a good set
Old Apr 24, 2005 | 08:31 AM
DIFFUT'S INC.'s Avatar
buddy club 4's or wait for some buddy club 5's one of my buddy has them but have not put then on yet or some skunk 2 pro 1's
Old Apr 24, 2005 | 08:36 AM
JBBNJ609's Avatar
Default Re: best 2.1 all motor cams? (DIFFUT'S INC.)
im hearing the pro 1 are a little weak, the stage 5s are out, i can get them, but is there anything better ?
Old Apr 24, 2005 | 08:37 AM
Innovation's Avatar
Have Rocket or Web make you a custom set. Shelf cams are only going to get you so far.
Old Apr 24, 2005 | 08:53 AM
usdm_dc2's Avatar
Default Re: best 2.1 all motor cams? (Innovation)
is this a race or daily driven setup?
Old Apr 24, 2005 | 09:00 AM
Top Ramen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard &raquo;</TD></TR><TR><TD CLASS="quote">best 2.1 all motor cams? </TD></TR></TABLE>
Stroker motor? I would think with that geometry, you would be making max power around 7800 - 8200 rpm (guess), so look for cams with strong mid-to-upper peak power and not something that needs to wind out to 9K +, especially if you are going to drive it on the street.
my .02
Old Apr 24, 2005 | 09:35 AM
Default Re: best 2.1 all motor cams? (Top Ramen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard &raquo;</TD></TR><TR><TD CLASS="quote">im hearing the pro 1 are a little weak, the stage 5s are out, i can get them, but is there anything better ? </TD></TR></TABLE> na they not out my buddy had then for about 6 months now but he all the way on the other side of the world
Old Apr 24, 2005 | 09:57 AM
Innovation's Avatar
Just because its a stroker motor doesnt mean it wont make power past 8200...
Your cylinder head, cam and intake manifold selection have more to do with where the motor will make pwoer than the actual stroke will
Old Apr 24, 2005 | 10:12 AM
rhd's Avatar
rhd
RLZ stage 3's!
that's what i ran in my 2.1L at least...i LOVED them
Old Apr 24, 2005 | 10:30 AM
JBBNJ609's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIFFUT’S INC. &raquo;</TD></TR><TR><TD CLASS="quote"> na they not out my buddy had then for about 6 months now but he all the way on the other side of the world</TD></TR></TABLE>
ok well they are out to me thats fine, i can get them
my engine is a 84mm bore and 89 mm stroke, but i have custom rods, and pistons , for a custom rod ratio
i can safely rev to ten or so
my head is fully built, and ported/polished by HEADGAMES MOTORWORKS
my setup is perfect for some very large cams, i am way undercamed rigth now
custom cams will be prob a bit of money, i wonder if its worth it
Old Apr 24, 2005 | 10:31 AM
rhd's Avatar
rhd
84x89 isn't really a 2.1...
i was 85x92 and that's only a 2.088L
Old Apr 24, 2005 | 10:33 AM
JBBNJ609's Avatar
Default Re: (rhd)
o ok then, well im a 2.0 then i guess
but im making very good power, with just a base tune
Old Apr 24, 2005 | 10:56 AM
asubennett's Avatar
Default Re: (jason bouchard)
What cam are you currently running? I can't imagine a Skunk2 Stage Two, JUN3 etc.... being undercammed on a 12.5:1 motor. I ran JUN3's with my 14.x:1 motor and it performed beautifully on the VTEC lobe. Left something to be desired under the curve however.
I believe big stroke motors can make great power into the 9,000's if the head can flow huge amounts of air. Piston speed plays a big role in breathing and of course a stroker motor has plenty of piston speed.
Let us know what your using your motor for, drag or road racing
then tell us how much you drive it on the street
Cams make or break a motor in terms of how and where power is delivered and how your car behaves itself if driven daily. I think all of us would feel terrible if we recommend you the holy grail of power making cams and you didn't have enough vaccum to operate your power brakes. lol
Old Apr 24, 2005 | 01:24 PM
JBBNJ609's Avatar
Default Re: (asubennett)
i drive it on the street alot, but im out with a crazy idle, i measn i have itbs so im used to being undriveable
Old Apr 24, 2005 | 01:27 PM
rhd's Avatar
rhd
give RLZ a call....brad can do custom grinds too
1-704-262-7948
Old Apr 24, 2005 | 01:33 PM
JBBNJ609's Avatar
Default Re: (rhd)
hmm, kool yea i will have to see if i can get a new 2.0 block first haha
https://honda-tech.com/zerothread?id=1221608
Old Apr 24, 2005 | 01:44 PM
rhd's Avatar
rhd
wow, that sucks man....
i guess it's time to resleeve and go with some nice AEBS sleeves...
Old Apr 24, 2005 | 01:52 PM
PAndADc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard &raquo;</TD></TR><TR><TD CLASS="quote">hmm, kool yea i will have to see if i can get a new 2.0 block first haha
https://honda-tech.com/zerothread?id=1221608 </TD></TR></TABLE>
so it wasn't ur gasket after all???
Old Apr 24, 2005 | 04:30 PM
JBBNJ609's Avatar
Default Re: (PAndADc2)
no, it looks like bad piston the wall clearances . . damn
Old Apr 24, 2005 | 05:59 PM
Top Ramen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation &raquo;</TD></TR><TR><TD CLASS="quote">Just because its a stroker motor doesnt mean it wont make power past 8200... </TD></TR></TABLE>
I know that, but it does have a significant impact on where max torque will be. The geometry is not really an issue in his case, though because he only has a 89mm stroke.
Old Apr 27, 2005 | 12:19 PM
JBBNJ609's Avatar
Default Re: (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">among other things. </TD></TR></TABLE>
what do you mean by that ??
Old Apr 28, 2005 | 02:16 PM
JBBNJ609's Avatar
Default Re: (JohnnieChimpo)
haha so about 2.1 then ?? thanks man
Old Apr 28, 2005 | 03:10 PM
Aquafina's Avatar
Rocket Motorsports M24X's.
298/12.7IN 305/12.1EX
Tbone has made very good numbers with these cams on his setup.
Skunk2 Pro1's also seemed to do very well on his setup as well (M24X is available in the M24XX. Bigger primaries for a boost in midrange).
Old Apr 28, 2005 | 03:53 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Rocket will custom grind you something as well. It may just take longer to get though. Shoot him an email and see what he thinks.
