oil pressure problem
Old Apr 23, 2005 | 10:21 PM
si937's Avatar
Default oil pressure problem
gotta b18c obd1/ problem is that im not getting enough oil pressure to the head for vtec to kick in. only 22psi..everything works.. we checked the block and was getting 80psi. changed all the orphices. cleaned all the screens. we even ran ls/vtec setup to see if the block was pluged and still was not working..all the oil ports are fine..please help
Old Apr 24, 2005 | 05:03 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: oil pressure problem (si937)
You're only getting 22psi? At what RPM?
Old Apr 24, 2005 | 05:56 PM
si937's Avatar
3000rpm.. i had courtney green work on it and he couldnt find out why it was so low..thats y im kinda losing hope but i dont know its gotta be something way stupid
Old Apr 25, 2005 | 01:04 PM
PURPLETERROR aka BIGMATT's Avatar
what headgasket did you use, and have you swapped in a working vtec selenoid? Need a little more info, was this motor/head just assembled or installed? where are you measuring 22psi of oil pressure?
Old Apr 25, 2005 | 09:10 PM
si937's Avatar
k i use a oem gasket... i bought the motor from this shop called driven motorsports in california, which i got riped from.. he said he did a compression and leak down test , changed head gasket, thermastat, water and oil pump.. everything was working.took his word on it..seemed lugit..the day i bought it, i was draining the oil and there was water and milky color oil coming out, so i know the motor had ran with a blown headgasket.. so i took the head off, and saw on the outside of the piston there was some rust., like the motor has been sitting for a while.. called him said that the motor was sittin out in the rain for a week...(i should of just took it back to him and got my money back) so i went and got it resurfaced. got it all cleaned up, clean all the oil ports. put it back together and there was no vtec, so i thought i had a bad selenoid changed the selenoid and body and still wasnt working.. so i called courntey green and i had him work on it. he changed all the orphices, checked oil pressure from the front side of the head and got 22psi so we checked the block and got 80psi.. so we changed the oil filter and selenoids and still not working. so next we ran a ls vtec setup to see if that the block was cloged and still wasnt working..so there obviously something in the head... so i just put a b16 head on and its working now. end result i have spent 450 on the parts he said he changed..
did my compression and C 1 was 140, C 2 was 136, C 3 was 140, C 4 was 145 is that good? i know its on the low side..should it be higher if its a b18c.. but i wanna send my gsr head out to find out the problem and port/polished it..any suggestions?
Modified by si937 at 12:34 PM 4/26/2005
tobster
Mar 13, 2011 12:32 PM
Acidcrakker
Jul 25, 2009 09:10 PM
bigmacks
Aug 25, 2005 02:08 PM
SleepinTeg
May 26, 2005 05:32 PM
lemongreenhatch
Jun 26, 2004 07:24 AM
