air/fuel problem
Old Apr 23, 2005 | 02:11 PM
2khb's Avatar
Default air/fuel problem
Just installed air/fuel gauge and it keeps reading extremely lean to not even lite and every now then it would jump up but not always when i would accelerate. Also switched to the connectors so it would read the secondary sensor and it just lights up like a christmas tree while driving, just going back and forth between rich and lean. Think it's the o2 sensor but a friend had a similar problem and his was the mass air sensor. Does anyone have any idea what the problem might be, has someone had a siimilar problem?
Old Apr 23, 2005 | 03:07 PM
4drmadness's Avatar
I have normally seen this when it's not hooked up to the right spots,in my experience. Just make sure all the connections are right and solid.
good luck...
Old Apr 23, 2005 | 06:11 PM
PrettyLude's Avatar
check the wiring, or if that's not the case, the sensor is bad then
Old Apr 23, 2005 | 06:18 PM
Lord Helmet's Avatar
Default Re: air/fuel problem (2khb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2khb &raquo;</TD></TR><TR><TD CLASS="quote">Just installed air/fuel gauge and it keeps reading extremely lean to not even lite and every now then it would jump up but not always when i would accelerate. Also switched to the connectors so it would read the secondary sensor and it just lights up like a christmas tree while driving, just going back and forth between rich and lean. Think it's the o2 sensor but a friend had a similar problem and his was the mass air sensor. Does anyone have any idea what the problem might be, has someone had a siimilar problem?</TD></TR></TABLE>
Is it a narrow band or wide band a/f gauge?
Old Apr 24, 2005 | 05:41 AM
2khb's Avatar
Default Re: air/fuel problem (sleeperciv)
I believe a narrow, it's a auto meter. We hooked it up to the white wire, there were two used the middle one, on the blue connector to the ecu on a '00 dx hatch, y7 motor.
Old Apr 24, 2005 | 07:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2khb &raquo;</TD></TR><TR><TD CLASS="quote">I believe a narrow, it's a auto meter. We hooked it up to the white wire, there were two used the middle one, on the blue connector to the ecu on a '00 dx hatch, y7 motor.</TD></TR></TABLE>
It's a narrow band then, auto meter's a/f gauge are only usable when it is at WOT hence the narrow band. You're getting the lean conditions because the gauge can't see the full "rpm band" that a wide band a/f gauge will show. It will show only the higher rpm range where the wide band will show everything from idle up to redline. It's a waste of time and money for having the Autometer a/f. It's more the bling then function. Get a real a/f ratio like: PLX M-300, Innovate LM-1, AEM, or any other wide band a/f ratio moniter.
Old Apr 24, 2005 | 07:40 PM
b18c1civic95's Avatar
it doesn't have anything to do with the rpm range it is because it is 0-1 volt instead of a wideband - 5 volt.I'm assuming yur refering to how that exact display works? that doesn't make anysense. how does the guage know what rpm it's at? It only knows what mixture is passing the sensor its hooked to. and obviously it will be richer. but like he said definetly get a wideband 02 setup....sensor/controller/gauge. if you looked at the wideband display at cruise you would see a similar oscillation as with the lights going backand forth kinda like the stock (narrowband) 02 does while trying to maintain a 14.7 (STOICH) condition.
Old Apr 24, 2005 | 07:55 PM
Default Re: air/fuel problem (b18c1civic95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1civic95 &raquo;</TD></TR><TR><TD CLASS="quote">it doesn't have anything to do with the rpm range it is because it is 0-1 volt instead of a wideband - 5 volt.I'm assuming yur refering to how that exact display works? that doesn't make anysense. how does the guage know what rpm it's at? It only knows what mixture is passing the sensor its hooked to. and obviously it will be richer. but like he said definetly get a wideband 02 setup....sensor/controller/gauge. if you looked at the wideband display at cruise you would see a similar oscillation as with the lights going backand forth kinda like the stock (narrowband) 02 does while trying to maintain a 14.7 (STOICH) condition.
Let me rephrase it: power band. it only works at a higher rpm at full load at WOT.
1sikhatch
Mar 8, 2007 11:16 AM
jowy
May 15, 2005 05:07 PM
ludedude48
Jan 25, 2005 11:12 PM
street_ruler
Jan 2, 2005 11:09 AM
40oztoFreedom
Sep 2, 2004 04:39 PM
