Water leak in 93 Hatch
Old Apr 23, 2005 | 01:51 PM
EM2Civic's Avatar
Default Water leak in 93 Hatch
I read most of the threads about it recent and archived and was just wondering. I don't really care about the trunk area but my car leaks into the passenger side floor area (front and back). Before I strip the whole interior and check for things I just wanna make sure I got most of the spots covered.
Windshield area (windshield and under the wipers cowl section)
Firewall and the unibody
Weather Stripping (Check no cuts or leaks)
Hood pop cable where the rubber gromet is
Floor for holes
Rear Window sealing
Anyone have a pic of where the wires run through the firewall? I'm not exactly sure where it is. What type of sealant should I use?
Is there anything else I should check before stripping the whole interior?
Can this be the problem? This it the passenger side foot area with carpet off. This is close to the ecu pretty much behind the glove box. Should I seal this hole?
Just noticed where that hole is that whole gray piece (sound deadning?) is soaking wet so I guess that means I gotta take off the dash to see where the leak is coming from?
Modified by EM2Civic at 4:39 PM 4/24/2005
Old Apr 23, 2005 | 08:29 PM
SwappedTURBOegg's Avatar
Default Re: Water leak in 93 Hatch (EM2Civic)
i have a leak in my hatch too...my car is fully gutted with no carpet and the water was under the floor mat.. i odnt have the cover for the wiper motor areia/blower?
so im thinking [in my case anyways] that water is comeing through the firewall. so maybe check that areia?
goodluck
Old Apr 23, 2005 | 09:56 PM
EG-CX's Avatar
I have a small leak under the driverside carpet. I'm going to remove the carpet soon and hope to fix it this summer.
Old Apr 24, 2005 | 07:03 AM
EM2Civic's Avatar
What type of sealent should i use? There are a bunch, I heard 3m weather adhesive. Should it be silicone based or something like that anyone have experience with a good sealant for cars.
Modified by EM2Civic at 4:33 PM 4/24/2005
Old Apr 24, 2005 | 09:02 AM
EM2Civic's Avatar
Bought some sealant patch up the hole in the firewall where the wires lead into the passenger footwell there was some sealant but it seemed to be flexing. Hopefully that was the only hole which I doubt cuz there was a puddle and I don't think that much water would come through that hole.
TTT guys need help it's raining from today till friday!
Old Apr 24, 2005 | 09:34 PM
l34l2l2y's Avatar
i got the same problem =[ leaks suck
Old Apr 24, 2005 | 09:57 PM
_Cyclone_'s Avatar
Default Re: (EM2Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2Civic &raquo;</TD></TR><TR><TD CLASS="quote">Bought some sealant patch up the hole in the firewall where the wires lead into the passenger footwell there was some sealant but it seemed to be flexing. Hopefully that was the only hole which I doubt cuz there was a puddle and I don't think that much water would come through that hole.
TTT guys need help it's raining from today till friday!</TD></TR></TABLE>
You'd be surprised just how much water can come in through a small hole. One more place I'd suggest you check is in your wheelwells. Since you're in Canada like me, salt eats that **** away and they rot into nothing. Get a screw driver and poke around in there lightly.
Old Apr 24, 2005 | 11:09 PM
CHiNkStEr's Avatar
i had a leak that soaked up my driver side carpet area. i got my windshield resealed and that solved the problem. dried right up.
Old Apr 25, 2005 | 08:14 AM
EM2Civic's Avatar
If I don't have any fender lining would that make a difference? Should i seal where the plastic plugs that hold the fender lining are? Since i don't have any fender lining would it get in through there?
Modified by EM2Civic at 6:21 PM 4/25/2005
Old Apr 25, 2005 | 11:10 AM
EM2Civic's Avatar
If I don't have any fender lining would that make a difference? The whole front end was just replaced with oem front though. I patched up some of where the original sealing is on the firewall hopefully that helps.
Old Apr 25, 2005 | 11:45 AM
_Cyclone_'s Avatar
I would seal them up just to be on the safe side.
Old Apr 27, 2005 | 03:20 PM
EM2Civic's Avatar
Patched up some things but it still leaks. Anyone think a garage can take care of this i'm close to giving up.
Old Apr 27, 2005 | 03:45 PM
743power's Avatar
the trunk on my eg hatch leaks like a 13 year old girl on her period. It used to fill up above the spare tire, but one day I was carrying a 4AGE block in my trunk and it poked a hole through the metal and the water all drains out now.
Old Apr 27, 2005 | 07:00 PM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
743power change your tail light gaskets.
Old Apr 27, 2005 | 07:26 PM
EM2Civic's Avatar
Default Re: (SpoolinEK9)
I think I determined that the leak is coming from the right top side of my foot area. There is a hole I see but can't patch without taking the dash out I think i'm gonna take out the glove box and see if that helps getting to it.
Old Apr 27, 2005 | 08:53 PM
SpoolinEK9's Avatar
i have a few un plugged holes in my firewall none of witch leak water. i would look somewhere else :/. or do this get a hose spray your care and sit there and watch for it.
Old Apr 28, 2005 | 05:39 AM
_Cyclone_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolinEK9 &raquo;</TD></TR><TR><TD CLASS="quote">i have a few un plugged holes in my firewall none of witch leak water. i would look somewhere else :/. or do this get a hose spray your care and sit there and watch for it.</TD></TR></TABLE>
Exactly. That's what I used to do at the shop. Go inside the car with a flashlight, and get the girlfriend to hose the car down in all areas, expecially around the cowl area. Tell her to get inside the wheelwells too, and spray the floor too right underneath the firewall. Make sure she isn't using any attachments on the hose, it should be open ended to provide a low pressure high volume stream of water.
Watch where the water normally accumulates on the floor... when you see it start, tell her to hold the hose where she had it, and trace your leak with the flashlight. That will be the end of your problem.
Old Apr 28, 2005 | 07:46 AM
Serio*Ferio's Avatar
Default Re: (CycloneBlue_1.6EL)
SOB, i have the same leak! ******* ****. and i had a grip of ants toooo
Old Apr 28, 2005 | 08:51 AM
sadangryboi's Avatar
if its not a hole on your floor...then i have no idea.
stock chassis has drilled holes all around the floor...for what reason i do not know. but they are filled with rubber fill of some kind and it might be coming out in the passenger hole area.
Old May 5, 2005 | 12:54 PM
CivicHP's Avatar
i have same problem passenger side floor soaked but i found where is the leak. You might try this. just peel off your carpet you don't need to remove it completly as long as you can get to the rubber underneath it just below the dash and goes behind ecu just lift it up( best way it from ecu side) and aske someone to poor water on the corner of the windshield you should see the water coming down from under the dash the reason is bad windshield cowl seal you have to remove both wiper and pull out the plastic cover air scoop whatever it called and aplly some silicon culk on top of the original black gritty **** it should fix the problem. even if most of the water build up behind the front seat dosent mean it coming from the back it take a slight level change to make the water run down so i don't think any car are perfectly leveled that is why you see water build up first on the back and slowly move it way to the front.
SoullessJapaneseMachine
Dec 7, 2007 11:31 AM
carlooooo
Feb 13, 2007 12:35 PM
12secteg
Jan 13, 2006 01:32 PM
kgard
Dec 8, 2005 01:47 PM
93CharcoalHatch
14
Nov 27, 2004 04:53 AM
