Swap issues
Old Apr 23, 2005 | 09:58 AM
jdmfun99's Avatar
Default Swap issues
Just dropped a 97 b18b in a 96 hatch, everything is plugged up. Well when i go to start, it turns over and sounds like it wants to start but it doesn't catch. I need suggestions on things to check that could relate to the problem. thanks
Old Apr 23, 2005 | 10:52 AM
jdmfun99's Avatar
top
Old Apr 23, 2005 | 10:54 AM
EG_intheworks's Avatar
Default Re: (jdmfun99)
Are you getting spark? pull a plug and crank it over.
Are you getting fuel? crank it with the spark plug out and stick your nose in there, try to smell some fuel. Also check your fuel pressure.
How is your timing? If this is wrong, you can have fuel and spark but no start.
Also try the hybrid forum they know their stuff
Old Apr 23, 2005 | 11:02 AM
GetawayInMoscow's Avatar
Default Re: (EG_intheworks)
Bad fuel pump maybe? Did it work before the swap?
Old Apr 23, 2005 | 11:11 AM
jdmfun99's Avatar
seems like I'm getting fuel, I can smell it. No spark however and yes the car ran before the swap
Old Apr 23, 2005 | 11:49 AM
h22 booster's Avatar
make sure that crank position sensor is connected. Make sure that plugs are good. Check the distributor cap and coil. If you have a spark, but the car still isnt' starting, check the firing order.
Old Apr 23, 2005 | 12:24 PM
jdmfun99's Avatar
Default Re: (h22 booster)
the crank position sensor, is that located by the distributor? I don't seem to be getting any spark either. bump
Old Apr 23, 2005 | 12:39 PM
dsmarefaster's Avatar
i got the same problem i have a 93 civic ex did a 94 ls b18b swap i have spark fuel but want start need some answers to geting code 41 injector and code 16 o2 sensor
Old Apr 23, 2005 | 01:04 PM
jdmfun99's Avatar
will it not start w/out the o2 sensors plugged in?
Old Apr 23, 2005 | 01:47 PM
Capt. Jimbo McSubipants's Avatar
i did a 96 b18b into my 98 hatch...started right up w/o the crank fluck and o2..sounds like a firing problem..do what this guy said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 booster &raquo;</TD></TR><TR><TD CLASS="quote">. Make sure that plugs are good. Check the distributor cap and coil. If you have a spark, but the car still isnt' starting, check the firing order.</TD></TR></TABLE>
Old Apr 23, 2005 | 01:54 PM
turbo_b16_ex's Avatar
your car will start w/o o2 hooked up
Old Apr 23, 2005 | 01:55 PM
Littlegreend15's Avatar
Default Re: Swap issues (jdmfun99)
had the same problem, check the cap and rotor, if they're good try the coil then the icm, mine was the coil, i replaced the plugs wires cap rotor and icm before the coil,
Old Apr 23, 2005 | 03:48 PM
jdmfun99's Avatar
thanks everyone, I'll give it a shot, bump
Old Apr 24, 2005 | 12:22 PM
jdmfun99's Avatar
ok, new dizzy, plugs, wires. Check the harness and grounds again. Checked fuel pump, reg, everything and still not getting spark. What else can I check, ecu, iginition switch etc. please help, bump
Old Apr 24, 2005 | 01:16 PM
jdmfun99's Avatar
up
Old Apr 24, 2005 | 05:30 PM
wow, still no spark? i'm stumped...
Old Apr 24, 2005 | 06:00 PM
Shudogg's Avatar
ecu, ignition coil packs, get a diagnosis and see where the signal stops - thats why your not gettin a spark
Old Apr 24, 2005 | 06:33 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: (Shudogg)
Wiring bro, no spark, new parts it has to be wiring. Check for voltage at the big wires to the dizzy with the key in the ON position. One will have 12v, can't remember if it's BLK/WHT of BLK/YEL, pretty sure it's BLK/WHT though. No CELS though?
Old Apr 24, 2005 | 06:41 PM
jdmfun99's Avatar
turns out that a crimped, exposed wire on the fuel pump kept blowing the fuse, replaced-runs fine, thanks everyone, up
dj-t
Jan 27, 2011 05:55 PM
si_motor_spt
Sep 2, 2007 06:57 PM
94civicEX
Mar 16, 2005 11:18 PM
94civicEX
Mar 16, 2005 11:17 PM
temp
15
Jul 6, 2004 08:07 PM
