z6 swap wiing
Old Apr 23, 2005 | 08:51 AM
SiRRedneck's Avatar
Default z6 swap wiing
my Q? is, i am using the stock crx si engine harness and i just switched the plugs needed from the z6 harness right now i have everything wired up exept for the 3 plugs that are connected or are right beside the injector rez. box that wasx used by the old harness, i need to know how those are wired up so that my z6 swap will work, i have the full Z6 harness, i know i have to swap in the 8 wire grey plug with the cap on it from the z6 harness, but i have no idea waht wires go were, if someone could plz help me out. thank you.
Old Apr 23, 2005 | 08:52 AM
SiRRedneck's Avatar
Default Re: z6 swap wiing (SiRRedneck)
i have the the full z6 motor thats with fuel rail, injectors, everything, and y8 intake,
Old Apr 23, 2005 | 11:06 AM
NikoZai's Avatar
on the 8 pin gray plug (we've named it the "block off plug") you plug them in anywhere. 1 12v+ wire feeding the other 4 wires back to the injectors.
Old Apr 24, 2005 | 08:11 AM
SiRRedneck's Avatar
Default Re: z6 swap wiing (NikoZai)
k well i just was told by another guy that its the yel/blk and the 4 red/blk injector wires taht have to be put in the 8 wire grey plug, i realy need to know what to do, what has to be done with the wires that are not goin into the 8wire grey plug.plz help
civicguy167
Jun 27, 2005 06:42 PM
SiRRedneck
Apr 24, 2005 10:05 AM
EGbeater
Nov 18, 2003 09:19 PM
Hatebreed215
Jan 17, 2003 08:26 PM
I Gotta Question
Jan 2, 2003 03:51 PM
