Fuel Rail Fab
I was curious if any of you machinests out there wanted to give a fuel rail a shot for a Miata? The miata market needs a good priced dual feed rail. Currently they go for around $225. They are pretty straight forward. I have some rail stock and a factory rail ready go so that the injector spacing and brackets are easy to figure out. I will pay for the first one and do test fitting. Its a good oppertunity for someone looking to break into a market outside of honda's.
I could also use fuel rails made for my audi.
I have http://www.rossmachineracing.com -10 fuel rail stock and the factory fuel rail. The cylinder spacing is 88mm.
Regards,
Justin
Regards,
Justin
Program is called Solidworks, Single User Seat will run you about 7k, definetly hurts the pocket book to say the least yet its so powerful and easy to use
Its similar to GE but they changed there fuel rail design awhile back to make it cheaper to machine and its not as pretty anymore
Who is Mr Robot?
how much for one of those for a b-series, howitt? are they able to use an external regulator like an aeromotive, what size are the inlets, outlets
I am still looking for someone that can make me one. The injectors i am using (2nd Gen RX7 Turbo) need a smaller pocket in the rail than most other injectors. I'd really like to get this done fairly soon so if anyone has time to take on the project and also come up with a marketable and sought after product, shoot me an IM.
(solidworks)
