Power window install w/ SPAL window kit
Old Apr 22, 2005 | 07:53 PM
pisetup's Avatar
Default DIY: Power window install w/ SPAL window kit
Howdy!
This is my tutorial on how to install power windows in a CRX utilizing the JDM power window switches and the SPAL power window kit.
The diagram attached shows how I did it. You dont necessarily have to do it my way, but this method worked out fine for me.
Here are the items I bought to do this whole project:
- SPAL power window kit
- JDM door panels
- JDM power window switches w/ the wire harness
- Relay w/ 5 pins (not sure what brand, it was free from this audio store)
- Automotive wire from Radio Shack
- Soldering equipment
- Solder iron
- Solder
- Quick disconnect connectors
- Spade terminals connectors
- Heat-shrink tubing
The drivers side was the side I installed first because the power window switch had only 5 wires. Those wires are:
- Blue w/ yellow
- Blue w/ green
- Blue w/ red
- Blue w/ white
- Blue w/ black
Power window wiring (Drivers' side)
Blue w/ yellow = grounded
Blue w/ green = grounded
Blue w/ red was attached to the red wire coming out of the SPAL motor
Blue w/ white was attached to the black wire coming out of the SPAL motor
Blue w/ black was attached to pin #87 in the relay
Relay wiring
Now for the relay wiring portion:
#85 = grounded
#30 runs straight to the battery
#87 gets attached to the blue w/ black wire (drivers' side) and the white w/ yellow wire (pass. side). So you have to split the wire coming out of the relay to go into those two wires.
#86 goes into the #3 fuse slot in the fues box. The reason why this was done is so that the windows can only be opened when there's a key in the ignition.
Power window wiring (Passengers' side)
Red w/ yellow was attached to the black wire coming out of the SPAL motor
Red w/ blue was attached to the red wire coming out of the SPAL motor
White w/ yellow gets attached to #87 out of the relay
Black = ground
The JDM master power window switch is on my passenger side and it has the ability to control the other window but I chose not to do that. I just want the windows to go down.
Props go out to Louie B. from the CRX Owners Club and Jordan for all the help.
Sticky this if you'd like. Thanks
Modified by pisetup at 3:42 PM 4/24/2005
Old Apr 22, 2005 | 08:06 PM
Bjorn20's Avatar
Default Re: Power window install w/ SPAL window kit (pisetup)
im confused... im not the greatest with wires and electronics
Old Apr 22, 2005 | 08:08 PM
pisetup's Avatar
The box that says "Power window switch" is the drivers' side switch. I did that side first. And if you buy the JDM window switches, you'll see that it has 5 wires. And you can see those in my professionally done diagram.
Old Apr 22, 2005 | 08:20 PM
Louie B.'s Avatar
Default Re: (pisetup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pisetup &raquo;</TD></TR><TR><TD CLASS="quote">And you can see those in my professionally done diagram. </TD></TR></TABLE>
Very professional indeed
Old Apr 22, 2005 | 08:22 PM
pisetup's Avatar
I absolutley DESPISE wiring and try to avoid doing any wiring. But I refuse to bring it to a shop and pay someone to do this. It looks so simple until I looked @ the wiring diagram. So I went to the CRX Owners Club and asked Louie B. for help. It took me two weeks of communicationg on that board. But well worth the wait.
Old Apr 22, 2005 | 09:53 PM
nautica_t's Avatar
heh, nothing beats oem power windows :D
Old Apr 22, 2005 | 10:32 PM
GSRCRXsi's Avatar
Default Re: (nautica_t)
dont you need one motor for each side? im a little confused on that.
Old Apr 22, 2005 | 10:38 PM
pisetup's Avatar
Yes, my bad. This is my first tutorial and I apologize if it is not 100% accurate.
The SPAL kit comes w/ two motors, one for the drivers' side and one for the passengers' side.
The black wire out of the SPAL motor gets attached to the red w/ yellow wire out of the window switch.
The red wire gets attached to the red w/ blue wire out of the window switch.
The white w/ yellow gets attached to #87 wire, and #87 is coming out of the relay.
And black is ground.
Old Apr 23, 2005 | 06:54 AM
Wes V's Avatar
Pisetup;
If you happen to know, could you please state what pins 1 through 5 are on the fuse block.
Wes
Old Apr 23, 2005 | 09:08 AM
pisetup's Avatar
Default Re: (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie B. &raquo;</TD></TR><TR><TD CLASS="quote">
There are other places on the fuse box to plug into that will only give power when the key is on. The under dash fuse box has 5 "outputs" shown in the picture below. One of them is 12v at all times (#5), one is 12v with the parking lights on (#2), one is 12v when the key is on (#3, this is the one you need), and I forget what the other 2 do.
You can try plugging directly into #3 but I'm a little worried that that output won't be able to handle the current load of the window motors. If you want to run through a relay you can run the #3 of the fuse box to #85 of the relay, #86 of the relay to a ground, #87 of the relay to your current power source, and #30 to your switches.</TD></TR></TABLE>
Old Apr 23, 2005 | 11:40 AM
crxtreme89h's Avatar
Holy ****! Nice write-up! Send this to FAQ so we have it Archived in an easy to view place.
I am a wiring Guru; mostly alarms and alarm add-ons. This is the shizzle.
Old Apr 23, 2005 | 04:27 PM
explictness's Avatar
Hell yeah, ima try and do this within the next month or so. nice write up.
Old Apr 23, 2005 | 06:17 PM
pisetup's Avatar
Thanks.
Old Apr 23, 2005 | 07:51 PM
I just wanna make sure I understand this right,which side are your switches on? You can roll both windows down from the drivers side right?
Old Apr 23, 2005 | 08:06 PM
Louie B.'s Avatar
Default Re: (Why49)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Why49 &raquo;</TD></TR><TR><TD CLASS="quote">I just wanna make sure I understand this right,which side are your switches on? You can roll both windows down from the drivers side right?</TD></TR></TABLE>
He has the JDM "right hand drive" switches, one switch on our driver's side, 2 on the passenger.
With the way he's wiring it you'll just have one switch on each side working it's own window so you'll still have to reach across to open tha pass window. the 2nd switch on the pass side is left dead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">I am a wiring Guru; mostly alarms and alarm add-ons. This is the shizzle. </TD></TR></TABLE>
That's how I knew about the 3 outputs on the Honda fuse box. Almost all hondas have those outputs on their fuseboxes and it's an easy shortcut for adding an aftermarket keyless entry. you have your constant, switched, and light flash right there. You just need lock wires and door pin and you're done Not too good for security though, real easy for someone to reach down and unplug the alarm.
Old Apr 24, 2005 | 08:33 AM
pisetup's Avatar
Hey Louie...I gave ya props. I posted this on 8 different Honda sites.
Old Apr 24, 2005 | 09:09 AM
crxkane's Avatar
Default Re: (Louie B.)
That's how I knew about the 3 outputs on the Honda fuse box. Almost all hondas have those outputs on their fuseboxes and it's an easy shortcut for adding an aftermarket keyless entry. you have your constant, switched, and light flash right there. You just need lock wires and door pin and you're done Not too good for security though, real easy for someone to reach down and unplug the alarm.</TD></TR></TABLE>
is there a way to hook it up with this kit and the jdm switches and make use them on the othere side to make the have the driver with 2 and the pass. with 1 so that you can have all switchs working and still roll down the pass. window from the driver side?
Old Apr 24, 2005 | 09:10 AM
pisetup's Avatar
There's a bunch of other wires on the master power window switch. I would PM Louie B. and ask him 21 questions.
Old Apr 24, 2005 | 04:13 PM
Louie B.'s Avatar
Default Re: (crxkane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxkane &raquo;</TD></TR><TR><TD CLASS="quote">
is there a way to hook it up with this kit and the jdm switches and make use them on the othere side to make the have the driver with 2 and the pass. with 1 so that you can have all switchs working and still roll down the pass. window from the driver side?</TD></TR></TABLE>
I haven't seen the switches in person but I've been told the JDM switches can't be swapped from one side to the other.
I think you can get some EDM or CDM switches though.
Old Apr 24, 2005 | 07:08 PM
pisetup's Avatar
I tried looking for the EDM switches but to no avail.
Old May 3, 2005 | 05:08 PM
Bjorn20's Avatar
heh, power windows beats the manual windows... only wish i understood wires and electronics to know wtf im even looking at in that diagram. ud have go down to the basic basics lvl of electronics to teach me how to do that lol
but ya, doing it urself beats the damn labor fees at shops
Old May 3, 2005 | 05:27 PM
darb2k's Avatar
Default Re: (Bjorn20)
those, places that are labeled, 1-5 on the fuse, panel, what are they used for. explain?
Old May 3, 2005 | 06:56 PM
darb2k's Avatar
Default Re: DIY: Power window install w/ SPAL window kit (pisetup)
Old May 3, 2005 | 08:27 PM
Louie B.'s Avatar
Default Re: (darb2k)
I'm not sure what Honda meant for them to be there for other than to be nice and give us a simple place to tap into for aftermarket accesories. I've never seen them being used for anything factory and as I said earlier (or was that in another thread?) Almost all Hondas have them.
Old May 3, 2005 | 09:04 PM
darb2k's Avatar
so its a straight 12v power? do they all come on with the ignition??
