89 civic si w/1st gen ls vtec.
is it only my car or does anyone else have a problem with the left/front caster bar rubbing against the crank pulley and sometimes even tearing the alt. belt off
i think they are made by mad engineering. came with the car. i guess thats why the bar was bent when i bought it. this problem started when i bent the bar straight again. guess ill have to bend it back
If you are going to change the mounts, I suggest using a complete set instead of using different pieces. Your motor may not sit straight with different mounts.
