skunk intake manifold for 1st gen. b16a
Old Apr 22, 2005 | 04:51 PM
rjc89sir's Avatar
Default skunk intake manifold for 1st gen. b16a
does anybody know what parts or mods. are needed to install a skunk manifold in a 1st gen. b16a. my main concern is the iac valve,fast idle valve,fuel rail etc.
Old Apr 23, 2005 | 04:42 PM
theinfamouskonrad's Avatar
Default Re: skunk intake manifold for 1st gen. b16a (rjc89sir)
all the sensors and fuel rail bolt up like stock. Only thing is making a bracket for your throttle cable.
Old Apr 23, 2005 | 08:09 PM
insomniac791's Avatar
No your fuel rail will not line up like stock! On the first gen the fuel pressure regulator is in the middle of the fuel rail. If you put it on your new manifold your fuel pressure regulator will hit the sensor. You need to get a newer fuel rail to make it work. Also on the 1st gen b16s the FITV was made onto the Intake manifold but the 2nd gen b16 had a slightly larger throttle body with the FITV made onto it. So you either have to bypass the FITV or get a newer throttle body.
if you have any questions feel free to pm me
later
Matt
redED9Si
10
Jun 26, 2005 06:48 PM
JG90CRX-Si
Feb 3, 2005 06:28 PM
SkankWorksDA
Dec 12, 2003 09:57 PM
