thoughts on low to high boost transition
Old Apr 22, 2005 | 02:53 PM
BEEYOND's Avatar
Default thoughts on low to high boost transition
anyone using the low to high boost transition off the line.... thinking about doing 20psi off the line in 1st and in 2nd... then in 3rd hit a bottom and run 30psi down the 1/4mile...
anyone have a better ideal.. maybe even 4 boost level for each gear down the 1/4mile.???
how has the turboXS dual stage worked for the experienced in HT???
suggetions would be appreciated!!!
Old Apr 22, 2005 | 03:00 PM
vaporboy12's Avatar
Default Re: thoughts on low to high boost transition (lsvtecpower)
you can use a turbo xs dual stage for that there are a few people out there with the momo boost controler that run 4 setting hehe
Old Apr 22, 2005 | 04:19 PM
Ekasey's Avatar
Default Re: thoughts on low to high boost transition (vaporboy12)
I would do a similar thing but setup boost by mph and by gear whihc you can do with the EMS you should know that
Old Apr 22, 2005 | 05:53 PM
turtle-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecpower &raquo;</TD></TR><TR><TD CLASS="quote">anyone using the low to high boost transition off the line.... thinking about doing 20psi off the line in 1st and in 2nd... then in 3rd hit a bottom and run 30psi down the 1/4mile...
suggetions would be appreciated!!! </TD></TR></TABLE>
I have a turboxs dual stage controller... it works pretty well but alot of other people has had problems with them leaking.
btw, isn't 20psi going to be too much boost off the line, traction wise?
Old Apr 22, 2005 | 06:00 PM
FormulaGSR's Avatar
Default Re: thoughts on low to high boost transition (turtle-eg)
what engine management systems will allow you to do this? I know AEM will. Can you have a high/low boost option on hondata, fast or neptune?
Old Apr 23, 2005 | 05:20 AM
ykracing's Avatar
Default Re: thoughts on low to high boost transition (FormulaGSR)
the innovative MSBC1 does gear based boost control also... and works very well.
Old Apr 23, 2005 | 10:53 PM
vaporboy12's Avatar
Default Re: thoughts on low to high boost transition (ykracing)
neptune does aswell
turboda4dr
Jan 27, 2013 07:48 AM
portenio78
Engine Management and Tuning
Jun 29, 2011 09:40 AM
RobbieG35
Jul 4, 2006 04:42 AM
S2KP
Jul 28, 2004 06:36 AM
JrCRXHF
Nov 13, 2003 03:50 AM
