B20 in a DA: what's needed
friend is planning to swap a b20 into his '90 integra. since the integra is obd0 and the b20 is obd2, what parts are needed to be swapped over?
what kind of ecu could be used? (92+ LS would be fine?)
what needs to be changed? engine harness? sensors?
ive found some info, jsut not enough..
i think you can use everything off of the stock motor on to your b20 like the harness and tranny...you can use the same ecu if your using the same harness...i think.
Nameless RB26
14
Jul 29, 2009 06:10 PM
