Mig welding experts need some help
Old Apr 22, 2005 | 01:58 PM
RCautoworks's Avatar
Default Mig welding experts need some help
I was cutting my line today for the wire, and I forgot I had the one piece off the gun. So the line is a little short, but not that bad, probably about 1/4 inch to 1/2 inch to short. The guy at the welding place said I would be fine, he said it had nothing to do with the mig welding gas. Just the wire feeding threw it. So my question is, was he right ? Or will the gas be interupted ?Just want to know if I should buy a new line or not ?
The piece I'm holding is the piece I forgot I took off. When everything is screwed all together , including the tip, the liner is about 5 to 10mm away from each other
Edited : I think I was suppose to leave that piece off, or else the liner would be hitting the tip. Anyone care to share though ?
Modified by 90blackcrx at 5:55 PM 4/22/2005
Modified by 90blackcrx at 6:35 PM 4/22/2005
Old Apr 22, 2005 | 02:54 PM
Default Re: Mig welding experts need some help (90blackcrx)
Here is a weld I just did, I'm not asking for whats wrong. I just want to know if it looks like gas is being used ? I want to make sure gas is not escaping. If gas was leaking anywhere before the mig wire, would I be able to feel it ?
Old Apr 22, 2005 | 03:17 PM
I read the instructions over and over, and I think that piece was suppose to be off when I cut it. Because if it was on, the liner would be coming out of the nozzle. But I just want to hear others opinions to be on the safe side of things
Old Apr 22, 2005 | 03:31 PM
m3dia_lab's Avatar
the weld looks horriable.
Old Apr 22, 2005 | 03:32 PM
Default Re: (m3dia_lab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m3dia_lab &raquo;</TD></TR><TR><TD CLASS="quote">the weld looks horriable.</TD></TR></TABLE>
Wow you sure know how to read don't you, I could care less on how bad it looks. I just need to know if it looks like gas was used
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Here is a weld I just did, I'm not asking for whats wrong. I just want to know if it looks like gas is being used ? I want to make sure gas is not escaping. If gas was leaking anywhere before the mig wire, would I be able to feel it ?
Old Apr 22, 2005 | 04:45 PM
F.A.'s Avatar
Default Re: (90blackcrx)
I still don't have an idea of why you might be worried about this. But anyways, you're fine, gas is working and there's nothing wrong.
Old Apr 22, 2005 | 05:31 PM
Engloid's Avatar
OG Fabricator
Default Re: (F.A.)
Yeah, it will work fine like that. The only problem I could forsee would be if the wire started wadding up between the end of the liner and the contact tip.. but use it if it works.
For future:
screw that piece in your pic on there. Then you want to trim the liner so that you have to use the contact tip to push it in and then turn the tip to thread it in. In other words, you want the liner to kinda be compressed in there. Many people don't do this...but many people have a lot of problems with wirefeed.
Old Apr 22, 2005 | 06:47 PM
Default Re: (Engloid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, it will work fine like that. The only problem I could forsee would be if the wire started wadding up between the end of the liner and the contact tip.. but use it if it works.
For future:
screw that piece in your pic on there. Then you want to trim the liner so that you have to use the contact tip to push it in and then turn the tip to thread it in. In other words, you want the liner to kinda be compressed in there. Many people don't do this...but many people have a lot of problems with wirefeed. </TD></TR></TABLE>
Totally understand, so if the liner is not compressed in there, will there be any problems with the gas feed or leaking or anything ?
Old Apr 22, 2005 | 07:29 PM
Engloid's Avatar
OG Fabricator
Totally understand, so if the liner is not compressed in there, will there be any problems with the gas feed or leaking or anything ?</TD></TR></TABLE>
no. not very likely at all.
spooledhonda
33
May 30, 2011 10:49 AM
KooK
Welding / Fabrication
Jan 7, 2009 06:24 AM
spooledhonda
Sep 17, 2007 10:33 AM
fullsleeves
Feb 25, 2007 10:10 PM
fandango
Mar 23, 2005 02:05 PM
