Why does it backfire when I take a sharp turn??
Old Apr 22, 2005 | 01:17 PM
FOMULA91's Avatar
Default Why does it backfire when I take a sharp turn??
I recently found out that my CRX backfires when I turn in 2nd gear. After I turn the corner, I lose power for a second then boost (making the popping sound from the exhaust) back to normal in 3rd, 4th, and 5th. Any idea??
Old Apr 22, 2005 | 01:22 PM
vegaskurt's Avatar
Default Re: Why does it backfire when I take a sharp turn?? (FOMULA91)
what engine and intake do you have?
Old Apr 22, 2005 | 01:46 PM
FOMULA91's Avatar
Default Re: Why does it backfire when I take a sharp turn?? (vegaskurt)
The engine is D15B2 and are you asking about the air intake?
Old Apr 22, 2005 | 02:03 PM
vegaskurt's Avatar
just wondering if you have a mpfi or dbfi setup. if its a stock d15b2 then its dpfi (dual point)
Old Apr 22, 2005 | 02:08 PM
FOMULA91's Avatar
I searched and people say it’s the timing but I already fix that for my smog check.
This only happens on 2nd gear when I’m turning.
Old Apr 22, 2005 | 02:56 PM
91civicEX's Avatar
have you done any home made wiring on the car? could be a loose connection
Old Apr 22, 2005 | 03:19 PM
FOMULA91's Avatar
Default Re: Why does it backfire when I take a sharp turn?? (91civicLX)
No, but do you guy’s think a lose exhaust might cause the problem? I have a universal exhaust, which I got it from some ghetto muffler shop. I was thinking that when I turn, the piping might lose or something because nothing really happens after I drive straight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">have you done any home made wiring on the car? could be a loose connection</TD></TR></TABLE>
What kind of wiring do you think I need to fix??
Old Apr 22, 2005 | 03:48 PM
FOMULA91's Avatar
OK, I went to test drive it but this happens when I turn slowly or fast. I shift to first, start diving and when I start to turn, “BAN” I lose my power and I could hear popping sound under my exhaust. WTF is going on? It drives fine when it is a straightaway but not when I turn. Any other advises?
Old Apr 22, 2005 | 04:18 PM
tur3oDC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 &raquo;</TD></TR><TR><TD CLASS="quote"> then boost (making the popping sound from the exhaust) </TD></TR></TABLE>
Your running a turbo?? - wheres your oil dump line on your oil pan?
Old Apr 22, 2005 | 04:51 PM
FOMULA91's Avatar
Default Re: Why does it backfire when I take a sharp turn?? (whitepoweredlsvtec)
It’s not a turbo. It boost because after the turn, I have no power (when it’s backfiring) then suddenly I get my power back, which gives me the boost.
Old Apr 22, 2005 | 04:57 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 &raquo;</TD></TR><TR><TD CLASS="quote">I have no power then suddenly I get my power back, which gives me the boost.</TD></TR></TABLE>
Damn, you must have VTEC or something
I've never heard of this before... Does it do it in all gears when you turn? or Just 2nd?
92jdmhatch's Avatar
could be something electrical.....
Old Apr 22, 2005 | 05:35 PM
koolb's Avatar
Default Re: Why does it backfire when I take a sharp turn?? (92jdmhatch)
loose motor mount and short fuel hose? Seriously that is some crazy stuff but thats my best guess! good luck
Old Apr 22, 2005 | 06:11 PM
turbohappy's Avatar
Default Re: Why does it backfire when I take a sharp turn?? (koolb)
How hard are you turning and how much gas do you have? Sounds like fuel starvation to me.
Old Apr 22, 2005 | 07:10 PM
FOMULA91's Avatar
Default Re: Why does it backfire when I take a sharp turn?? (turbohappy)
I check the ECU and it was giving me code 10 (intake air temperature sensor).
Now it happens when I start in 1st and 2nd gear. FUCKKKKKKKKKK.
Old Apr 22, 2005 | 07:48 PM
FOMULA91's Avatar
The CRX manual said that the TA sensor is the problem but my D15B2 dose have a TA sensor connecter but it is covered with some kind of glue (color is gray) but it was running fine before, so I guess it has nothing to do with the intake air temperature sensor. Any other idea?
Old Apr 22, 2005 | 11:09 PM
bagpipe goatee's Avatar
my car does that when the gas is low in the tank.
i'd investigate that. if it does it with plenty of gas, maybe the sock filter on your pump is coming off or coming apart.
Old Apr 23, 2005 | 12:06 AM
FOMULA91's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">my car does that when the gas is low in the tank.
i'd investigate that. if it does it with plenty of gas, maybe the sock filter on your pump is coming off or coming apart.</TD></TR></TABLE>
Thanks for all the info guys. I'll try to fill up my tank tomorrow and see if it goes away. BTW I drove like 277 miles.
zeBRAHz
Aug 4, 2009 10:22 PM
Blackline47
Honda Civic (2006 - 2015)
Dec 7, 2006 02:58 PM
taffetawhitegsr
Oct 22, 2004 11:39 AM
Senbonzakura
Apr 11, 2004 03:34 PM
JMod
Aug 14, 2003 03:03 AM
