Somone tell me whats wrong here
Old Apr 22, 2005 | 12:26 PM
EM1VtecSi's Avatar
Default Somone tell me whats wrong here
I looked at my engine bay because I wanted to see how the hole looks without my fender lining from another post, and I noticed that my engine is maybe forward or out of normal position. I had to tighten the drivers side motor mount not to long ago, but didnt notice this:
From what you can see, the engine looks like its in normal position, but the engine seems to have actually tilited forward, and now that sensor on the top of the intake manifold is being pushed against the strut bar. There is no gap between the bar and the sensor, and the bar is pushing the sensor down somewhat, but hasn't broken it.
Old Apr 22, 2005 | 12:30 PM
IHateJDM's Avatar
Default Re: Somone tell me whats wrong here (EM1VtecSi)
have you looked at your rear motor mount lately?
rasinhell's Avatar
rear mount
Old Apr 22, 2005 | 12:31 PM
714phil's Avatar
It is not your rear mount. You have the bar on backwards. Flip the bar around 180 degrees.
Old Apr 22, 2005 | 12:50 PM
Junkie Si's Avatar
Default Re: Somone tell me whats wrong here (STD ONEpointSIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ONEpointSIX &raquo;</TD></TR><TR><TD CLASS="quote">It is not your rear mount. You have the bar on backwards. Flip the bar around 180 degrees.</TD></TR></TABLE>
exactly
Old Apr 22, 2005 | 01:08 PM
JDMFreak's Avatar
ditto, im with him...
Old Apr 22, 2005 | 01:41 PM
94_HATCH's Avatar
Default Re: Somone tell me whats wrong here (The-Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Beast &raquo;</TD></TR><TR><TD CLASS="quote">rear mount</TD></TR></TABLE>
Or another mount thats not tight.
If you look at the strut tower bar its mounted fine. If he were to flip it 180 degrees it would be hitting the intake mani directcly. See its curves upward right now. if he were to flip it it would curve downward...if that makes sense.
Old Apr 22, 2005 | 01:48 PM
714phil's Avatar
Default Re: Somone tell me whats wrong here (94_HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_HATCH &raquo;</TD></TR><TR><TD CLASS="quote">
If you look at the strut tower bar its mounted fine. If he were to flip it 180 degrees it would be hitting the intake mani directcly. See its curves upward right now. if he were to flip it it would curve downward...if that makes sense.</TD></TR></TABLE>
It's on backwards, look at the pic.
Old Apr 22, 2005 | 01:51 PM
IHateJDM's Avatar
It's on backwards, look at the pic.</TD></TR></TABLE>
I agree, it's really hard to see in that first pic of his though.
Old Apr 22, 2005 | 02:37 PM
EM1VtecSi's Avatar
Default Re: Somone tell me whats wrong here (IHateJDM)
Got it, someone in the last few months has put it on backwards, now i'm stuck trying to get this thing on straight. For now i'll ride with out it
Old Apr 22, 2005 | 03:22 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
yep the bar is backwards, i have the same one too. Better take off the bar and change it before that sensor gets damaged
Old Apr 22, 2005 | 03:48 PM
CIVIC dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1VtecSi &raquo;</TD></TR><TR><TD CLASS="quote">Got it, someone in the last few months has put it on backwards, now i'm stuck trying to get this thing on straight. For now i'll ride with out it</TD></TR></TABLE>
why ride with out it?
its 4 bolts, unscrew them, turn the bar around, re fasten the bolts ur done
you do know how to use a ratchet? right? get to ittttttt
Old Apr 22, 2005 | 05:11 PM
Aphelion's Avatar
huh? Are you misunderstanding something about the bar being on backwards?
Old Apr 23, 2005 | 02:47 AM
chartinael's Avatar
Default Re: Somone tell me whats wrong here (Aphelion)
Yes, definitely the bar is on backwards. just loosen the four nuts, pull up bar, flip it 180° horizontally and drop it back on the bolts, tighten the bolts and you are all done. 5 minutes would eb my guess.
kristin
Old Apr 23, 2005 | 03:43 AM
Tetronious's Avatar
Default Re: Somone tell me whats wrong here (chartinael)
I did the same thing to mine once, and had the strut bar on backwards.. Ugh broke the top clip on the map sensor. Electrical tape fixed though and its never gave me and trouble with its connection since. Funny how we can make mistakes when not paying attention to detail. Ah well
00 SI
Boosted
Ash J. Williams
20
Jan 9, 2013 08:00 PM
t_ank
Apr 13, 2010 09:58 PM
h22 civic
Apr 20, 2007 02:59 AM
Black R
May 26, 2004 10:56 AM
10K2HVN
Jun 25, 2003 12:08 AM
