What next
well as a result of a stuck open wastegate and a massive 17lb boost spike this is my stock head/block turbo z6 i already have a new block but it has 210,000 miles on it. I was going to take it to the machine shop and have them re-ring it, and shot peen the rods possibly get everything blue printed and balanced,( im going for a cheap reliable rebuild . I was wondering how much around "SHOULD" this cost me so when i go down there i can know what it should cost vs what they are gonna charge, thanks!!
if yu have another block already just tear it apart and replace the pistons, rings, rods, bearings, seals....ect...ect... full bottom end build up. or send it out to be built.
boost boost boost.......
WOW....nice man. Good luck with the rebuild hopefully you will find something to get it back on the road.
Are they suppose to have metal in the oil pan? Guess I better add some to my car
I got my block cleaned, crank balanced, new rods/pistons/rings/and new main and rod bearings put in and it ran me $200 even. (thats for the labor not including parts)
jtmoney2002
May 12, 2008 05:57 AM
Wish i could help you bro...good luck with the re-build
