got a huge problem with the rex again HELP.........................................
Old Apr 22, 2005 | 10:37 AM
1ludeEK's Avatar
Default got a huge problem with the rex again HELP.........................................
well got a cel for a vtec solinoid. replace the solinoid and its still throwing a code for vtec solinoid, but it was running good. it was just running like i had a 1.6 liter without vtec. now heres comes the real problem. last night i was driving it and out of nowhere its starts misfiring and dumping fuel in the engine. i drove it back home, which was about 15 miles and i waste about a whole tank of gas. got it back home pulled the plugs and the number3 plug was soaked. removed the distributor and cleaned the icm, and put it all back together and retimed it and still the same problem. what could be wrong. i was on a bad deadline for today and i didnt make it. please help me oh i talked to a tech at the dealer and he said without the vtec solinoid it would run like a regular engine. thanks in advance
Old Apr 22, 2005 | 10:45 AM
89 crix si's Avatar
Default Re: got a huge problem with the rex again HELP......................................... (rex owner)
maybe the injector is stuck open or something? and for vtec not working, heres a link with some things that you can check --> https://honda-tech.com/zerothread?id=830163 hope this helps!
Old Apr 22, 2005 | 11:02 AM
1ludeEK's Avatar
Default Re: got a huge problem with the rex again HELP......................................... (89 crix si
check the resistenceon all the injectors and they were 2.4 ohms. they were no open or shorted.
Old Apr 22, 2005 | 11:13 AM
2kTeg's Avatar
it could still be that injector swap it out with a known good one
Old Apr 22, 2005 | 02:07 PM
1ludeEK's Avatar
Default Re: got a huge problem with the rex again HELP......................................... (2kTeg)
so what fuel injectors (from what donor vehicle) should i get for my obd0. if i only need one, than what stock one can i use that will match the other three that i have in there now.
Old Apr 22, 2005 | 04:33 PM
vegaskurt's Avatar
swap injectors with another cylinder, if the problem follows to the other cylinder then you at least isolated the problem.
Old Apr 23, 2005 | 03:44 PM
1ludeEK's Avatar
Default Re: got a huge problem with the rex again HELP......................................... (vegaskurt)
well i swap all four injectors and the problems worse. i got even more raw unburn fuel coming out of the exhaust. got spark at all four cylinders. pulled the spark plugs and the number 3 three was soked. all others were fine. do i have bent valves? or do i have a icm problem? somebody plese help me before i decide to burn this car to the ground.
Old Apr 23, 2005 | 07:44 PM
bagpipe goatee's Avatar
it sounds like your wiring. i'm assuming you used to have dpfi? it sounds like whoever did the wiring did a hack job, the wires for the #3 fuel injector are shorting out and the wire for the vtec solenoid broke somewhere.
i could be wrong, but thats how it sounds to me.
Old Apr 24, 2005 | 05:04 PM
vegaskurt's Avatar
Default Re: (bagpipe goatee)
If your plugs are soaked then the injectors are opening. Could be something simple like your distributor not firing the spark plugs, or your fuel return line is clogged and to much gas is being let in to the cylinders.... Im no expert but I would check those out first.
xKAMILxEK
Mar 19, 2010 04:58 PM
01em2slvr
Honda Civic (2001 - 2005)
Nov 11, 2009 12:43 PM
newbbb
34
Oct 10, 2008 01:37 AM
aznguy0087
May 9, 2007 06:11 AM
Got Milk
Dec 30, 2005 08:13 AM
