whp needed to produce a 12second ET???
Old Jan 31, 2002 | 09:36 AM
Pinhead's Avatar
New User
Default whp needed to produce a 12second ET???
what whp would I need to obtain a 12second et considering I am a good driver and I run on nitto drag radials and get 60' times of about 2.0-2.1??? I'm thinking 200+????
forget to mention this is N/A horsepower
[Modified by typerman1358, 6:36 PM 1/31/2002]
Old Jan 31, 2002 | 09:37 AM
HX_Guy's Avatar
Default Re: whp needed to produce a 12second ET??? (typerman1358)
Car weight?
Old Jan 31, 2002 | 09:39 AM
Pinhead's Avatar
New User
Default Re: whp needed to produce a 12second ET??? (HX_Guy)
stock ITR weight....plus 150 with me in it
HX_Guy's Avatar
Which is?
Old Jan 31, 2002 | 09:40 AM
Pinhead's Avatar
New User
probably a bit under 2800 with me in it
Old Jan 31, 2002 | 09:41 AM
HX_Guy's Avatar
Umm...Im going to take a stab at it and say 230+ WHP
Old Jan 31, 2002 | 09:42 AM
Pinhead's Avatar
New User
what about on slicks? 15x8x22 with some 9lb rims
ThePunk's Avatar
It took Rboosted717 250+WHP to hit High 12's in street trim and full weight.
(He's supercharged BTW)
Pinhead's Avatar
New User
Default Re: whp needed to produce a 12second ET??? (ThePunk)
what could I do to drop weight.....to shave some time off??? I gutted my trunk..that's about it
Old Jan 31, 2002 | 09:43 AM
PM-Performance's Avatar
I would guess over 200whp. 230 should be there for sure.
depends on weight too ,. mark brauning in think is like 1600 lbs or something like that and 217 hp at the wheels all motor and he is fast as hell . . . i think like 10's or so off hand
Old Jan 31, 2002 | 09:45 AM
HX_Guy's Avatar
Default Re: whp needed to produce a 12second ET??? (itr206)
Well, look at my car...
2450 - 2500 w/ driver
208 HP / 152 TQ
13.3 w 2.15 60 ft
Also, the torque is really going to matter.
Old Jan 31, 2002 | 09:52 AM
sgT's Avatar
sgT
dont compare marc brauning.
#1, he has a large displacement H motor. that means more torque
#2 that motor is in a tube chassis car
#3 he doesnt use gas
Old Jan 31, 2002 | 09:55 AM
Pinhead's Avatar
New User
Default Re: whp needed to produce a 12second ET??? (sgT)
well if im only 300lbs more than the hxguy....and I have 12 more whp or so with my engine bored out to a 1.9 or so and have a better 60'time that should yields at least 13 flat
Old Jan 31, 2002 | 09:56 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
It depends on how you want to go about doing it. If you want to keep the stock redline, it'll take about 250+ hp, if you want to rev up to about 9200 it'll only take about 230 because the area under the curve (or average wheel hp during the course of the run, however you prefer to look at it) is much larger with an extended redline.
Old Jan 31, 2002 | 09:57 AM
BoM's Avatar
BoM
drop your car to around 2300 lbs and you'll get 12's with 210whp
drop the ac, drop the seats, drop the spoiler, change the hood,
ect.....
Old Jan 31, 2002 | 09:58 AM
Pinhead's Avatar
New User
Default Re: whp needed to produce a 12second ET??? (newt2)
well guys.....looks like I got tons of work ahead of me
Old Jan 31, 2002 | 10:02 AM
HX_Guy's Avatar
100 LBS = roughly 7 WHP across the board. So you would need 21 more HP everywhere then my car to be as fast. On slicks, I would guess high 12s.
Plus you cant bore a B18C to 1.9L
Old Jan 31, 2002 | 10:03 AM
sgT's Avatar
sgT
you can bore to 1.9L
Because technically all you need to "round up" is 35ccs.
Old Jan 31, 2002 | 10:04 AM
Pinhead's Avatar
New User
yes im ordering the endyn 84.5mm 11.8:1 pistons mmmmmm
Old Jan 31, 2002 | 10:05 AM
sgT's Avatar
sgT
why going low compressoin?
Old Jan 31, 2002 | 10:06 AM
TypeR0207's Avatar
Unless something has changed, when I talked to Mark at the middle of the 2000 season, he had just tuned it to 265-ish ....... so he de-tuned last year?
Old Jan 31, 2002 | 10:07 AM
Pinhead's Avatar
New User
Default Re: whp needed to produce a 12second ET??? (TypeR0207)
well I only want to use 93 octane.....seriously what's an extra .2-.4 gonna do hp whise???what do you guys say i should get...i wanna hear some expert opinions
Old Jan 31, 2002 | 10:10 AM
OBD-One-Kanobe's Avatar
New User
slicks would help.
weight is definitely an issue, when shooting for 12s
HX_Guy's Avatar
Blah..Im talking about true 1900cc
Old Jan 31, 2002 | 10:14 AM
sgT's Avatar
sgT
LOL
