New Satellite Vehicle Tracking Option
Old Apr 22, 2005 | 08:19 AM
AamirCWITR's Avatar
Default New Satellite Vehicle Tracking Option
While browsing on Friendster I found this banner add that read
"Spouse Tracking Systems
Track your wife or husband w/ GPS. Complete for $295. No Monthly Fees!
http://www.Vehicle-Tracking.com"
Check it out, one time fee, constant satellite tracking of your R!
http://www.vehicle-tracking.com/products/7100.html
Some one should try it out
Aamir
Old Apr 22, 2005 | 08:27 AM
p nut's Avatar
The LandAirSea 7100 is a web-based real time tracking system that uses GPS technology to accurately determine the exact location of your vehicle.
The LandAirSea 7100 does not require a set monthly service fee. The fees that are related to the amount of tracking you do is called Fair and Flexible Tracking. You can set the unit to update its location while the vehicle is moving and can be set to update in the following increments : 5, 15, 30, 60 minutes, 4 hours, daily or weekly. The costs for these automatic location updates are shown in the table below. If you are only going to use your tracking device to occasionally track its location, these are called pings. Pings are billed at 25 cents each.
The unit also has 3 inputs which can be connected to your vehicle's alarm system or airbag inflation system to inform you if your alarm is going off or if your airbag was inflated.
You can also use the LandAirSea 7100 to disable your vehicle from driving anywhere in the event that it was stolen. The LandAirSea 7100 is very easy to install on your vehicle. It comes with a single antenna and a power cable that connects directly to your battery or fuse box.
Sounds pretty good.
Old Apr 22, 2005 | 08:46 AM
AamirCWITR's Avatar
Default Re: (P Nut)
INSTANT $100 Rebate
04/18/05 - 04/22/05
Our Price : $495.00 Availability: In Stock
Looks like its on sale till tomorrow.
Old Apr 22, 2005 | 08:53 AM
Azcheron's Avatar
Default Re: (AamirCWITR)
GPS tracking is not very useful
as soon as they pull your car into a garage or shop, guess what, you cant track it
it needs line of sight to the sky
Old Apr 22, 2005 | 09:04 AM
SecretAgent's Avatar
Default Re: (Azcheron)
not quite. but being inside buildings, especially large one such as parking garages, can distort or lose the signal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">GPS tracking is not very useful
it needs line of sight to the sky</TD></TR></TABLE>
Old Apr 22, 2005 | 09:07 AM
p nut's Avatar
I think you can also get a route history, so you can at least pinpoint where the car was the last time it received signal.
Old Apr 22, 2005 | 09:55 AM
AamirCWITR's Avatar
Default Re: (P Nut)
You can basically track it to the moment it went underground.
Still seems extremely useful, unless all theives live in complex underground parking garage mazes.
Old Apr 22, 2005 | 12:38 PM
citrus3000psi's Avatar
I would think that the gps antenna would need to see the sky so i would think it would be easily visable by theifs. So once they catch on they will just cut the antenna.
What they need to do is just adapt a cell phone technology that just stays in your car and when you want to find your car you just call it. I think the 3g uses gps to sycronize there tower pulse so you in turn would know what tower your using, then by using the air delay you would know how far your car is from the tower...this would make a priemeter; but you would find it sooner or later. Hopefully sooner.
Old Apr 22, 2005 | 12:44 PM
DC2IntegraTypeR's Avatar
Default Re: (citrus3000psi)
Edit: someone mentioned cell phones...
If you have 2 cellphones you can leave one turned on and in your car
I used to work for AT&T wireless (Now Cingular...blah blah blah) and in all their (current) GSM cell phones there is a GPS tracking device. So if you have a flat tire, you're lost, you presume your girlfriend is cheating on you, etc. Just call the operator and they'll be able to pinpoint where you're calling from or where your other phone is (ex: if it was stolen, or you want to check up on the girlfriend's location) at anytime.
Old Apr 22, 2005 | 01:08 PM
KayOs's Avatar
Default Re: New Satellite Vehicle Tracking Option (AamirCWITR)
This is not real time tracking. With the above, you need the actual unit to retrieve and plot the driving data to the software they provide.
Will do you no good if your car is stolen and you are unable to have remote or physical access to the unit.
Old Apr 23, 2005 | 01:43 PM
AamirCWITR's Avatar
Default Re: New Satellite Vehicle Tracking Option (KayOs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">This is not real time tracking. With the above, you need the actual unit to retrieve and plot the driving data to the software they provide.
Will do you no good if your car is stolen and you are unable to have remote or physical access to the unit. </TD></TR></TABLE>
Old Apr 23, 2005 | 02:00 PM
IGGY's Avatar
Well is says that you can have it active when an alarm goes off.
I don't know how smart the software is but I can think of a couple things.
1. If your alarm goes off and the theives cut your power and the alarm is no more. The GSP's thing is no good if they don't move the car and strip it where it is.
2. If you can start the tracking once the alarm goes off and the vehicle is in motion, then you can have it keep a record and if the car dissapears you can see where is was before it went missing on the GPS. However, this may pose a problem if your car is already in a garge parking complex, because you may never know if it left.
Old Apr 23, 2005 | 02:25 PM
Yellow Dragon's Avatar
I want something like this for my '69 Camaro SS when it's all completely restored.
xenocron
Engine Management and Tuning
17
Apr 22, 2012 10:20 AM
GoLowDrew
Hawaii & Asia-Pacific
17
Sep 24, 2008 01:13 PM
