Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
EX suspension on EF?
Old Apr 21, 2005 | 09:53 PM
uncleben's Avatar
Default EX suspension on EF?
In my desperate attempt to get in one more clean fast lap in my persuit of Bob Stretch's ITA track record at Hallett (I came within 0.01, can you believe that crap?) I managed to loop the car hard off the track, bending something on the passenger rear suspension. I can't tell what, everything looks straight, but I have just enough positive camber that you can see it with the naked eye. Seems that would have to be in the upper arm or where it connects to the spindle/hub, but I visually can't tell. A local shop has a dead 1990 EX sitting in their lot that I can have if I just drop it off at the salvage yard when I'm done. He thinks the EX stuff is identical to the EF Hatch, can anyone confirm this? If so I'll just take everything off the EX and see if that takes care of me.
thanks
Old Apr 21, 2005 | 10:46 PM
rsca_crx's Avatar
Default Re: EX suspension on EF? (uncleben)
i'm not sure about the rear stuff, but...
the front spindles are different (brakes are different) and i'm looking for a pair. if you pull the rear stuff off and grab the front spindles i'll gladly pay you for the parts and your time.
if you haven't already, put your post up in the ef forum. you'll get your answer pretty quick there i think.
a bent lca is shorter (positive camber)
a bent subframe can have similar effects too, but if you get it up in the air you can usually tell if the subframe is tweaked.
is the toe visually correct?
Modified by rsca_crx at 11:57 PM 4/21/2005
Modified by rsca_crx at 11:58 PM 4/21/2005
Old Apr 21, 2005 | 10:49 PM
civicrr's Avatar
According to my honda parts cd, the trailing arm, upper arm & compensator all have the same parts numbers. The lower arms have different parts numbers. this is for the 1990 ex & si, btw
Old Apr 22, 2005 | 12:02 AM
CRX-RX's Avatar
Default Re: EX suspension on EF? (civicrr)
Sounds like the trailing arm and spindle/hub assembly is what you are looking at replacking, and the EX parts will work.
Old Apr 22, 2005 | 01:25 AM
XrcR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrr &raquo;</TD></TR><TR><TD CLASS="quote">According to my honda parts cd, the trailing arm, upper arm & compensator all have the same parts numbers. The lower arms have different parts numbers. this is for the 1990 ex & si, btw</TD></TR></TABLE>
That would make sense, since I don't believe any US sedan came from the factory with a rear sway bar (or more simply only the CRX/Civic Si's came with one). So the difference in the LCA p/n would be one with threaded endlink hole or lack thereof. Which might be important if that is what is bent and you have a rear sway bar that utilizes the stock endlink mounting point.
Old Apr 22, 2005 | 05:19 AM
StageOne's Avatar
Default Re: EX suspension on EF? (CRX-RX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-RX &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the trailing arm and spindle/hub assembly is what you are looking at replacking, and the EX parts will work. </TD></TR></TABLE>
This is my bet too. When I tagged the wall with the rear, I could not see anything that was bent, but I had a bit of toe out. A honda mechanic showed me on the back of the trailing arm that there was a faint mark/dimple right where the spindle connects. I guess when the rear suspension gets hit, this is the most common "injury".
Old Apr 22, 2005 | 06:48 PM
uncleben's Avatar
Default Re: EX suspension on EF? (rsca_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx &raquo;</TD></TR><TR><TD CLASS="quote">the front spindles are different (brakes are different) and i'm looking for a pair. if you pull the rear stuff off and grab the front spindles i'll gladly pay you for the parts and your time.</TD></TR></TABLE>
i think the front passenger side is pretty smashed up, but I can check and see if anything on the front end is salvagable if I end up picking this thing up (still going to check at some local salvage yards)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx &raquo;</TD></TR><TR><TD CLASS="quote">is the toe visually correct?</TD></TR></TABLE>
toe was definitely OUT.
thanks everyone else, I'll check in EF forum to confirm as well
Old Apr 22, 2005 | 09:15 PM
rsca_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncleben &raquo;</TD></TR><TR><TD CLASS="quote">
thanks everyone else, I'll check in EF forum to confirm as well </TD></TR></TABLE>
thanks, and good luck with the parts find.
Old Apr 28, 2005 | 07:13 PM
OG LL C's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncleben &raquo;</TD></TR><TR><TD CLASS="quote">In my desperate attempt to get in one more clean fast lap in my persuit of Bob Stretch's ITA track record at Hallett (I came within 0.01, can you believe that crap?) </TD></TR></TABLE>
Hit me up next time you make it over to Hallet.
Old May 6, 2005 | 08:44 AM
uncleben's Avatar
Well the EX fell through. Doesn't a '90 CRX Si have the same rear bits aside from being disc brakes? Looks like I can get my hands on a Si shell... not sure what I will do with the rest of the thing when I'm done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OG LL. C &raquo;</TD></TR><TR><TD CLASS="quote">Hit me up next time you make it over to Hallet. </TD></TR></TABLE>
May 21st-22nd... SCCA race. Plus Todd and *hopefully* some others are doing the SCCA PDE for $100... really good deal. Anyone near Hallett should check it out
Old May 6, 2005 | 02:22 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncleben &raquo;</TD></TR><TR><TD CLASS="quote">Well the EX fell through. Doesn't a '90 CRX Si have the same rear bits aside from being disc brakes?</TD></TR></TABLE>
Yes, everything is identical. Only difference is the hub assembly itself for discs. Trailing arm is the same.
Old May 6, 2005 | 02:55 PM
civicrr's Avatar
Default Re: EX suspension on EF? (Targa250R)
problem is that you can't buy the hub from the factory....
JOEY F.
24
Aug 25, 2004 10:10 AM
alexdog69
Jun 22, 2004 05:29 PM
