Burning Oil to Fast... Engine Rebuilt?
Old Apr 21, 2005 | 07:28 PM
Jonboy385's Avatar
Default Burning Oil to Fast... Engine Rebuilt?
i have a 01 prelude w/intake, exhaust, and headers, and it use to be a showcar, but now a daily driver. so basically one mechanic told me my oil is burning to fast and i have a problem with the rings in my engine and my engine has to be opened. and another mechanic told me this is a common problem with show cars since they are turned on and off so much or something and the engine has to rebuilt and its $3000-$4000. i filled it up with synthetic oil 3 days ago and the dip stick shows about 75% gone. so basically, i dont got that much money at all, and i just need somebody i can trust and somebody that does good work for cheap in the los angeles area?
anybody know any good mechanics?
anybody had this problem?
anybody know what the problem is?
HELP
ps. i dont know that much about engines
Old Apr 21, 2005 | 07:49 PM
xbn83's Avatar
Default Re: Burning Oil to Fast... Engine Rebuilt? (Jonboy385)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonboy385 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 01 prelude w/intake, exhaust, and headers, and it use to be a showcar, but now a daily driver. so basically one mechanic told me my oil is burning to fast and i have a problem with the rings in my engine and my engine has to be opened. and another mechanic told me this is a common problem with show cars since they are turned on and off so much or something and the engine has to rebuilt and its $3000-$4000. i filled it up with synthetic oil 3 days ago and the dip stick shows about 75% gone. so basically, i dont got that much money at all, and i just need somebody i can trust and somebody that does good work for cheap in the los angeles area?
HELP
ps. i dont know that much about engines</TD></TR></TABLE>
Do the compression test and leak down test to know for sure. Don't take any word from any mechanic. Some of them are very dumb and don't know what the hell they are talking about.
Old Apr 22, 2005 | 09:51 AM
Jonboy385's Avatar
Default Re: Burning Oil to Fast... Engine Rebuilt? (xbn83)
"Do the compression test and leak down test to know for sure"
how do i do that?
any website on instructions
Old Apr 22, 2005 | 09:58 AM
RemerLex11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">Do the compression test and leak down test to know for sure. Don't take any word from any mechanic. Some of them are very dumb and don't know what the hell they are talking about.</TD></TR></TABLE>
its not that they're dumb its that they can easily rip people off, but yeah know for sure before you drop that much money
Old Apr 22, 2005 | 09:59 AM
951dc5's Avatar
you'll need a compression test tools that plugs in the spark plug hole and try starting the engine and it'll show you how much compression and it'll needs to reach around the spec of your car.
Old Apr 22, 2005 | 05:39 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonboy385 &raquo;</TD></TR><TR><TD CLASS="quote">"Do the compression test and leak down test to know for sure"
how do i do that?
any website on instructions</TD></TR></TABLE>
You could buy compression tester gauge at Pepboys, Autozone, Sears.... about $30. Search on internet for compression testing instruction, pretty easy tho.
Old Apr 22, 2005 | 08:26 PM
Jonboy385's Avatar
what about the leak down test, how do i do that
Old Apr 22, 2005 | 08:32 PM
edulerp97's Avatar
Default Re: Burning Oil to Fast... Engine Rebuilt? (Matt5745767)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 &raquo;</TD></TR><TR><TD CLASS="quote">
its not that they're dumb its that they can easily rip people off, but yeah know for sure before you drop that much money</TD></TR></TABLE>
This is so true...and for 3000 to 4000 thousands dollars **** you can build a strong bottom end.....And some..
And do the CP test.and leak down test...
Old Apr 24, 2005 | 06:05 PM
89s rule's Avatar
Did you do a break in on the engine before you installed the synthetic? I have always heard that you need to break it in with dino oil. or has it been rebuilt? your post is kinda confusing? i would definately say you have some issues either way if youy have that much oil gone.
Old Apr 24, 2005 | 08:13 PM
civlude_h23vtec's Avatar
pull your spark plugs out take a look at them, If they are black and oil soaked then either your cylinder walls are shot or your valve seals are leaking. trust me I have been down that road before. Do what everyone else says also (comp. test and leak down test). Good luck!
Old May 1, 2005 | 10:17 PM
Jonboy385's Avatar
thanks guys, i did a compression check on the car, and everything was fine, it was like 180 on all 4 cylinders and there was no oil spill anywhere, my spark plugs needed to be replaced though, but i dont see any problems.
Old May 2, 2005 | 07:33 AM
Monkey Fing a Coconut's Avatar
Default Re: (Jonboy385)
180 seems pretty low for 10:1 compression...but not low enough to warrant a rebuild, also, to rebuild to stock specs should cost less than a grand to replace rings and gaskets and what not...try calling prospeed or prostreet, both located in socal
CERRITOS.562
21
Aug 10, 2007 08:01 AM
ohsoslow
Mar 22, 2007 07:15 PM
xcerpt
Jul 1, 2006 09:36 AM
hockey_Fan59
May 3, 2005 02:22 PM
civichtchback91
Jul 2, 2004 02:45 PM
