D15B2 to D16z6 head/Y8 mani wiring diagram needed...
Whats is needed to get my P28 ecu plugged in?( The wiring harness is not the same) and the rest of the wiring to get it working. Do I need to buy a harness converter or other??
buy a harness the one I have is from http://www.jkobd.com I will vouche that it is a quality piece....you will also need a obd 1 distributer and 4 wire o2 sensor....you need an adapter for the dizzy....I got mine from http://www.rywire.com and it was also a quality peice.......also make sure you convert to mpfi before you do any of this.....I don't knwo anything about mpfi swaps so if you haven't don't it already you will need to ask someone else
Casey
Casey
Eyes Only
Aug 26, 2008 01:20 PM
puertoricanboy90
14
Aug 7, 2008 10:09 AM
