ignighters dont last 30 days
Old Apr 21, 2005 | 03:26 PM
cec97's Avatar
Default ignighters dont last 30 days
90 crx -zc ignighters olny lasting about 30 days? anyone got any soutions.
thanks
Old Apr 21, 2005 | 03:40 PM
Magick211's Avatar
Default Re: ignighters dont last 30 days (cec97)
Bump for the zc igniter problem. I always heard horror stories of igniters goind bad on zc's. The igniter on my old zc never went bad
Old Apr 21, 2005 | 03:41 PM
HatchBox's Avatar
Skoobie no more...
Default Re: ignighters dont last 30 days (Magick211)
reclace the whole dizzy?
just a idea.
Old Apr 21, 2005 | 03:57 PM
93formula's Avatar
Default Re: ignighters dont last 30 days (HatchBox)
when replacing the ignitor dont forget the white paste your supposed to put on the ignitor before installing. the white paste helps the heat transfer off the ignitor faster. heat is what kills ignitors.
Old Apr 22, 2005 | 11:05 PM
Magick211's Avatar
Default Re: ignighters dont last 30 days (93formula)
None of the menioned help his problem. For some odd reasons zc's always fry ignitors. Dont ask why. I dont know why but they do
Old Apr 22, 2005 | 11:07 PM
daidilus's Avatar
because they are old...the white paste or the lube in the bearing has degraded.....you wanna save your dizzy? put more heatsink paste on the igniter, and more lube for the bearings(axle grease) works wonders
Old Apr 23, 2005 | 01:29 PM
93formula's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">None of the menioned help his problem. For some odd reasons zc's always fry ignitors. Dont ask why. I dont know why but they do</TD></TR></TABLE>
did you even read my post???
Old Apr 23, 2005 | 03:13 PM
doublethink's Avatar
check the resistence of the ground, from the negative terminal of the battery to the dizzy.
if you have high resistence you could be shortening the life of electrical components since its stuggling to send that power back to ground.
also is this an OEM dizzy or distributor king or some Duralast autozone piece of ****?
could also be a bad design to the unit itself, not every honda part is perfect.
but i know nothing of ZC's specifically.
Old Apr 23, 2005 | 07:36 PM
bagpipe goatee's Avatar
also, if you have "performance" plug wires, go back to stock. the "performance" ones have much lower resistance, which causes more current to flow through, causing the igniter to heat more.
Old Apr 24, 2005 | 01:30 AM
daidilus's Avatar
Default Re: (bagpipe goatee)
I SEOND THAT ..........AND UMM 2 DIZZY LATER..SWITCHING BACK TO THE STOCK ONES MAKE MORE POWER!!!
z6htch
Oct 3, 2011 02:16 PM
1slow_dx
Nov 20, 2004 12:13 AM
zccrx
Aug 21, 2003 07:28 PM
bottledcrx
Sep 23, 2002 02:02 PM
SteveeeO
14
Sep 20, 2002 01:12 AM
