type r swap with idle problems, anyone???
Old Apr 21, 2005 | 01:00 PM
bottlefed13's Avatar
Default type r swap with idle problems, anyone???
i just got a swap done into my 2000 ex. the car was converted to an si so i'm running the si cluster too. when the car idles, the rpm bounces from 1000-1500 rpms. also when i drive and go pass 5500 rpms, the needles drops down to 0. i'm running a p28 ecu with the type r motor. anyone have any thoughts on this?
Old Apr 21, 2005 | 01:02 PM
IHateJDM's Avatar
Default Re: type r swap with idle problems, anyone??? (bottlefed13)
what chip in the p28? have any vacuum leaks on the IM?
Old Apr 21, 2005 | 01:05 PM
Default Re: type r swap with idle problems, anyone??? (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">what chip in the p28? have any vacuum leaks on the IM?</TD></TR></TABLE>
it's a copy of the mugen. chipped to hit vtec at 5500 and redline at 9200 nothing major. no leaks on the im. i ran a usdm b16 ecu and the car idles fine, and the rpm needle works fine. i just don't know what's goind on.
Old Apr 21, 2005 | 01:10 PM
IHateJDM's Avatar
I would start by looking for sensor wire changes (in their location at the ecu) from the b16 ecu and the p28. Maybe your chip has a bad burn on it. Do you know anyone with the same motor to test?
Old Apr 21, 2005 | 01:15 PM
nope. i wish i knew someone else. i just got this ecu reprogrammed a second time on monday, and just got it back today. thanks for the help.
Old Apr 21, 2005 | 03:34 PM
anyone else can help me?
cyhm
Aug 5, 2014 05:54 PM
stackedhouse
May 17, 2012 05:37 PM
DraginTeg93
Mar 19, 2007 07:10 PM
ZzZCivicZzZ
Aug 22, 2006 04:19 PM
SkoundrelUSA
29
Nov 10, 2005 06:28 PM
