Bolting on a cylinder head
Old Apr 21, 2005 | 12:28 PM
HONDA RR's Avatar
Default Bolting on a cylinder head
Do i need to oil the cylinder head bolts before i bolt it on or can i just bolt it on as is? Does it cause any kind of harm if i don't oil the cylinder head bolts?
Old Apr 21, 2005 | 12:54 PM
spoonek9's Avatar
Default Re: Bolting on a cylinder head (HONDA RR)
You need to use some sort of lubricant for the threads. This helps to get an accurate torque reading when you install them. YOU MUST DO THIS!!!
Old Apr 24, 2005 | 08:58 PM
pcguy760's Avatar
Hey will WD40 work for that? Just wondering...
Old Apr 24, 2005 | 09:24 PM
DavidT or VajT's Avatar
Default Re: (pcguy760)
Just lube them up with some oil...it'll only take a few seconds. Isn't hard bro...
Old Apr 24, 2005 | 10:14 PM
SlowReaction's Avatar
Default Re: (DavidT or VajT)
lube the threads and under the head of the bolt. I would personally use some kinda of assembly lube but oil works to. Make sure you clean the threads of each rod bolt good and chase the threads in the block.
Old Apr 24, 2005 | 11:04 PM
GeeSssAre's Avatar
Default Re: (SlowReaction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">lube the threads and under the head of the bolt. I would personally use some kinda of assembly lube but oil works to. Make sure you clean the threads of each rod bolt good and chase the threads in the block.</TD></TR></TABLE>
faran
Jun 20, 2013 12:36 PM
faran
Welding / Fabrication
21
Jun 18, 2013 06:32 PM
faran
Jun 14, 2013 07:02 AM
notnilc20
May 14, 2011 12:09 AM
