problem with dropping the dc5 (front strut)
Old Apr 21, 2005 | 11:57 AM
KOREAN's Avatar
Default problem with dropping the dc5 (front strut)
i first heard it from username: integra type s
is it true that after a certain amount of drop, the geometry of the front strut gets all funky? what's the problem?
Old Apr 21, 2005 | 12:19 PM
DC5ITR329's Avatar
Default Re: problem with dropping the dc5 (korean)
it doesn't get all crazy but it does change. I only lowered like .7 inch and I still got an alignment.
Old Apr 21, 2005 | 12:37 PM
KOREAN's Avatar
Default Re: problem with dropping the dc5 (aznbo1626)
what changes?
Old Apr 21, 2005 | 02:30 PM
DC5ITR329's Avatar
camber, toe and some other things will change. what are you going to put on?
Old Apr 21, 2005 | 03:05 PM
acurate's Avatar
so you needed a camber kit with only a .7 drop in the front?
doesnt the aspec kit drop it more than that, and without a camber?
Old Apr 21, 2005 | 03:39 PM
::MYCORD::'s Avatar
Default Re: problem with dropping the dc5 (acurate)
When you drop any car, the alignment of the car becomes misaligned. That's a given. The only problem that I really see is there is that when you drop the dc5 or the ep3, is that the amount of stroke will be greatly reduced from what little stroke these cars came with. It seems that the dc5 has a short stroke because of the macphearson strut design. This would mean that it would bottom out more and give some bump steer when lowered significantly.
Old Apr 21, 2005 | 03:48 PM
KOREAN's Avatar
my plans are omnipower coilovers, lca's, and omnipower camber kits. yeah, the package deal
either that, or i'll go with just ground controls
i was planning on slamming my car down, but i guess it's not possible...
any way around this problem?
Old Apr 22, 2005 | 03:41 PM
Reborn's Avatar
Reborn_
ive been slammed on tein flex for almost 2 years with no problems whatsoever with street driving. when i roadrace, i raise it up quite a bit though.
dacrxguy
10
Aug 26, 2009 06:02 PM
Chillmatic
Suspension & Brakes
Jul 20, 2009 06:47 PM
Halo
Oct 11, 2004 02:49 PM
RedHB..D15B
Apr 2, 2004 03:08 PM
