timing questions on ls swap
Old Apr 21, 2005 | 10:19 AM
jarvis199's Avatar
Default timing questions on ls swap
ok first off heres my setup:
b18a with b18b cams, hp racing header, short ram intake, custom 2.25" exhaust
ok i DO NOT have adjustable cam gears yet, but when i first replaced my timing belt before i installed the engine into my car for the first time i accidently retarded the intake cam timing 1 tooth, which made the engine pull very hard off idle, then i retimed it about 2 weeks later and now it doesnt pull AT ALL off idle and seems to rev slowly down lowtill around 4k and starts to speed up really well, i think i may have the exhaust cam a little off too and that might be affecting the engines ability to rev, anyway, is it safe to run the intake cam 1 full tooth retarded? because i seemed to enjoy the way the engine made power a WHOLE lot more then...
Old Apr 22, 2005 | 03:18 PM
jarvis199's Avatar
Default Re: timing questions on ls swap (jarvis199)
bump
anyone have any info?
Old Apr 22, 2005 | 03:24 PM
turbo_b16_ex's Avatar
re check the alignment of the crank and cam gears is what id do. I wouldnt **** with ur timing with stock gears. save ur money and buy some.
mountainrich
Classic Hondas
Jul 12, 2009 05:24 PM
Used2beAb16
Mar 26, 2006 10:32 AM
[HrZn]4life
May 13, 2003 03:17 PM
7rrivera7
Apr 3, 2003 02:00 PM
