Help! New SOHC setup with BogginG iSSueS!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">[b]you need to get a wideband on that before you ruin a brand new motor[b]
Edit: since it's already broken in, get a wideband on it and tune
dammit i dont know crap about this wideband thing PM me and school me i need to know more about this
oh btw Im still breaking in the setup i only got about 35-30 miles on it
</TD></TR></TABLE>dammit i dont know crap about this wideband thing PM me and school me i need to know more about this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">PMed</TD></TR></TABLE>
thanks!
thanks!
dude i have the same prob...I've got a built sohc, ported head blah blah blah But its only running the greddy blue box<---keep in mind that it was designed for 92-95 sohc with 240's, i have 310s and a walbro, fpr set at 35. I have the same symptoms, when ever i try to pass someone in 5th or even just keep up with traffic (especially going up small inclines) the car boggs like hell. I have an autometer a/f guage and yes i know they are not the best things on the planet, but i looked at it and whenever the car bogged the guage shot to green. So i'm guessing our cars are just running really rich in the low rpms and under medium to high load. I NEED TO GET THIS THING TUNED!!!
hope that helps you
hope that helps you
Its nothing to worry about. You just need to get your car tuned. I made my friend a basemap for his built b16 turbo setup the other day and he said it drove fine until he decided to get on it and then it would completely shut down and stutter. Turned out the basemap was way too lean(you really don't know until you have a wideband). I added some more fuel in and voila it pulled great.
I'm guessing your problem may be too much fuel though...
thanks for replying guys but i found something that mae me felt stupid a bit............
the downpipe had no o2 bung
so my o2 sensor is plugged up BUT not bolted into the downpipe maybe this can be the error??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skank_aSS_Dara »</TD></TR><TR><TD CLASS="quote">i'll pick the o2 problem my basemap was working fine before when i was daily driving it and doing my quarter mile times</TD></TR></TABLE> I would say it is but please get it tuned, if recall right your last engine didn't last to long. Tuning is the key.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi »</TD></TR><TR><TD CLASS="quote"> I would say it is but please get it tuned, if recall right your last engine didn't last to long. Tuning is the key.
"Please get it tuned" get it tuned yadda yadda i hear it all dammit, im breaking in the motor first atleast at 5-800 miles before tuning jeebus i know already....... my last setup lasted for about 4 months before it went out, i had a bad block i used to come out what went wrong on it
</TD></TR></TABLE>"Please get it tuned" get it tuned yadda yadda i hear it all dammit, im breaking in the motor first atleast at 5-800 miles before tuning jeebus i know already....... my last setup lasted for about 4 months before it went out, i had a bad block i used to come out what went wrong on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skank_aSS_Dara »</TD></TR><TR><TD CLASS="quote">"Please get it tuned" get it tuned yadda yadda i hear it all dammit, im breaking in the motor first atleast at 5-800 miles before tuning jeebus i know already....... my last setup lasted for about 4 months before it went out, i had a bad block i used to come out what went wrong on it</TD></TR></TABLE>
you can break in the motor right on the dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">
i'd rather not yet but to cruise and seat my rings for my proper way
</TD></TR></TABLE>i'd rather not yet but to cruise and seat my rings for my proper way
yea this would be causing you to run very rich in part throttle if you don't have it in the exhaust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">
yea this would be causing you to run very rich in part throttle if you don't have it in the exhaust. </TD></TR></TABLE>
Yes i got two people agreeing to this part maybe 3 yes okay so i might just have found my problems for now guys i'll get it fixed and inform you guys!
-dara
-dara
ok first of all. you need that o2 sensor put in, but only for closed loop. WOT it just uses the map you have setup.
are you running a basemap for the DSM injectors? and is it setup for boost at all? or are you running a bsaicly stock map?
if you don;t have the boost portion setup you may be flooding or running way to lean in boost. you should be breaking in the engine with the wastegate open so it bleeds off all boost, so you don;t see boost until the breakin is finished.
personaly i would have left the DSMs out and use a stock map, and stock injectors for the breakin to make sure you weren't running to rich or lean.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snail Tuning »</TD></TR><TR><TD CLASS="quote">ok first of all. you need that o2 sensor put in, but only for closed loop. WOT it just uses the map you have setup.
well basically im still using the basemap that was setup for me already from projekteg from hmt.com he did the setup for me inputting the info i provided him awhile back, so yes the setup is for a boost basemap, and o2 sensor was just a doh-doh mistake i forgot to do when the downpipe was made so i found my part of the bogging issues thanks for replying all!
-dara
-dara
JCracer723
11
Mar 24, 2003 01:27 PM
