Complete B16A Complete Change Over From H-Moters....question
Old Apr 21, 2005 | 08:17 AM
etp72's Avatar
Default Complete B16A Complete Change Over From H-Moters....question
The complete Changover comes wit axels with half shaft....i was curious as to what axles these are (90-93 integra?), and if you still needed to do anything like change the intermediate shaft...
Im about to order one, i have never done an engine swap before but i think its something i can probalby handle with the help of this site and the helms! It doesnt seem like it would be that difficult... We'll just let me know...
I'm also planning on changing the clutch, and maybe the flywheel when i throw it in
should I also change the t-belt?
Old Apr 21, 2005 | 08:23 AM
kurinto's Avatar
Default Re: Complete B16A Complete Change Over From H-Moters....question (etp72)
Yes change the timing belt and water pump, its so easy with the engine out and gives you piece of mind.
The axles they give you are out of the sir, you will need 90-93 teg axles.
And yes you can do it yourself. The hardest part is the wiring which, imo, isn't that hard. Just take your time.
Old Apr 21, 2005 | 08:25 AM
EP3_05's Avatar
The intermediate shaft with the swap will more than likely be a 90-91 integra. If you get the y1 trans you will have the y1 intermediate shaft which requires hybrid axles.
I would replace the clutch, timing belt, water pump, front and rear main seals, oil pan gasket, thermostat, plugs and plug wires, dist. cap and rotor, valve cover gasket.
Old Apr 21, 2005 | 08:41 AM
SQURL's Avatar
Default Re: Complete B16A Complete Change Over From H-Moters....question (91civic)
exactly what 91civic said and you will be happier in the long run
Old Apr 21, 2005 | 08:44 AM
Rywire's Avatar
Default Re: Complete B16A Complete Change Over From H-Moters....question (SQURL)
Yup, the axles depends what tranny you get(what car they source it from)
Old Apr 21, 2005 | 11:06 AM
91dxcrx's Avatar
Default Re: Complete B16A Complete Change Over From H-Moters....question (droppedcrxsi)
if i got the integra xsi b16a changeover, would those axles work in a crx?
Old Apr 21, 2005 | 11:33 AM
SwissChEz82's Avatar
Default Re: Complete B16A Complete Change Over From H-Moters....question (91dxcrx)
Not sure about the axles but if you are getting the XSi engine than you have to wire your car for OBD1 also, not just VTEC.
Old Apr 21, 2005 | 11:55 AM
gtarwiz's Avatar
Default Re: Complete B16A Complete Change Over From H-Moters....question (SwissChEz82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwissChEz82 &raquo;</TD></TR><TR><TD CLASS="quote">Not sure about the axles but if you are getting the XSi engine than you have to wire your car for OBD1 also, not just VTEC.</TD></TR></TABLE>
you dont HAVE to wire it to OBD-1. I have an XSi engine in mine and we converted it back to OBD-0. It was a bitch and took plenty of time but ti worked out in the end. So it doesnt have to be just OBD-1.
Old Apr 21, 2005 | 12:24 PM
Rywire's Avatar
Default Re: Complete B16A Complete Change Over From H-Moters....question (gtarwiz)
An xsi is the teg axles... so you use them with the axle boot, and hub ring removed. More at http://www.droppedcrxsi.com
DIYMIKE
Apr 12, 2007 03:04 PM
DIYMIKE
Mar 6, 2007 09:02 PM
etp72
Jun 28, 2004 12:02 PM
XANDER-666
Oct 7, 2002 12:04 PM
90-CRXSi
Jul 8, 2002 09:59 AM
