what is the difference between hf and dx
Old Apr 21, 2005 | 07:58 AM
SloCrxDx91's Avatar
Default what is the difference between hf and dx
ok, i was told i had a dx. but i looked on autotrader and it said i should have a 16 valve. i have an 8 valve. is there any other differences in the models? i thought i seen that the wiring harness for hf is good for engine swaps......is that true?
appreciate the help
Old Apr 21, 2005 | 08:45 AM
SQURL's Avatar
Default Re: what is the difference between hf and dx (SloCrxDx91)
dx is 16 valve, your motor is not a D15b2, its probably a D15b6. look under the dizzy where the tranny meets the block for the code, it might be dirty just wipe the dirt away. D15b2 is dx motor 16 valve 92 hp; D15b6 is hf motor 8 valve 62 bhp.
Old Apr 21, 2005 | 08:46 AM
crxtreme89h's Avatar
HF and DX Differences. DX has Passenger side mirror and rear wiper. DX has Dual Point Fuel Injection, HF has Multipoint Fuel Injection. Knuckles and hubs are different (DX=Larger) and can fit Integra Axles when doing motor swaps. Seats are different. 88 DX HF has piller mounted seatbelts. 89 HF has piller mounted seat belts. 89-91 DX has pillar mounted seat belts.
You're welcome to finish what I started. I don't feel like searching either.
Oh, and always use your stock wiring harness that is on the motor in the vehicle.
Old Apr 21, 2005 | 08:52 AM
Cprace1's Avatar
Default Re: what is the difference between hf and dx (crxtreme89h)
Also keep in mind the HF is lighter
Old Apr 21, 2005 | 08:55 AM
CRseXy's Avatar
Default Re: what is the difference between hf and dx (Cprace1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cprace1 &raquo;</TD></TR><TR><TD CLASS="quote">Also keep in mind the HF is lighter </TD></TR></TABLE>
yah, HF had Bumper suport Delete. also HF rods are smaller,
Old Apr 21, 2005 | 09:35 AM
Mach69's Avatar
Default Re: what is the difference between hf and dx (pogiTSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCrxDx91 &raquo;</TD></TR><TR><TD CLASS="quote">i thought i seen that the wiring harness for hf is good for engine swaps......is that true? </TD></TR></TABLE>
Wow, you thought you had a DX and you end up having an Hf, what a great surprise. You don't have to do the MPFI wiring and you have a lighter car. I would be happy with that find. So yes, the wiring harness for the hf would be a lot easier for an engine swap because you already have MPFI whereas he DX has DPFI. DPFI for performance or engine swaps.
Old Apr 21, 2005 | 09:41 AM
explictness's Avatar
Default Re: what is the difference between hf and dx (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">Wow, you thought you had a DX and you end up having an Hf, what a great surprise. You don't have to do the MPFI wiring and you have a lighter car. I would be happy with that find. So yes, the wiring harness for the hf would be a lot easier for an engine swap because you already have MPFI whereas he DX has DPFI. DPFI for performance or engine swaps.</TD></TR></TABLE>
damn i have dpfi kuz i got a Dx. damn
Old Apr 21, 2005 | 10:01 AM
Mach69's Avatar
Default Re: what is the difference between hf and dx (explictness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explictness &raquo;</TD></TR><TR><TD CLASS="quote">
damn i have dpfi kuz i got a Dx. damn </TD></TR></TABLE>
Don't worry, I once was in the same boat. I had a civic hatchback STD which was obdo and dpfi. I converted to mpfi and the only problem I ran into was a code 9, so i replaced the distributor and soldered new connections at the ecu and the problem was solved. MPFI is well worth it. I will soon be converting to obd1, I hope I had the same luck as I did when I converted to MPFI. Just search you will find every bit of information you ever needed on this forum to convert to mpfi, its fairl easy.
Old Apr 21, 2005 | 12:45 PM
SloCrxDx91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">HF and DX Differences. DX has Passenger side mirror and rear wiper. DX has Dual Point Fuel Injection, HF has Multipoint Fuel Injection. Knuckles and hubs are different (DX=Larger) and can fit Integra Axles when doing motor swaps. Seats are different. 88 DX HF has piller mounted seatbelts. 89 HF has piller mounted seat belts. 89-91 DX has pillar mounted seat belts.
Oh, and always use your stock wiring harness that is on the motor in the vehicle. </TD></TR></TABLE>
Thank you much! I have my crx in storage still, I will go check that out once I get it out of storage.
anek
10
Aug 9, 2006 04:56 PM
justamechanic
Oct 5, 2005 05:35 PM
5litereater
Jun 24, 2004 06:01 PM
Way2JDM
Mar 6, 2004 11:26 AM
GSRSNATCH
Apr 16, 2003 07:38 PM
