Crx Hf to Si brake question ??
Old Apr 21, 2005 | 07:14 AM
Si2See's Avatar
Default Crx Hf to Si brake question ??
I am buying a 91 crx Hf tonight. I want front only Brembo cross drilled and slotted rotors with like the pbr pads or what not. Will the ones for a crx si fit or do I need calipers too or anything else. I searched but could only find info on eg's. Basically this is what I had on my integra and this is what I want on the hf.
http://cgi.ebay.com/ebaymotors...&rd=1
Will it work? Thanks again guys
Old Apr 21, 2005 | 08:55 AM
crxtreme89h's Avatar
Default Re: Crx Hf to Si brake question ?? (Si2See)
I don't think they will fit. I had to swap my HF hubs for my B16 motor swap and I'm pretty sure the new rotors that I got were a different size than my old HF ones. His auction says 1.5 liter, but I am pretty sure he means 1.5 DX.
Old Apr 21, 2005 | 09:51 AM
Si2See's Avatar
ok cause i plan on doing a b16 swap sometime within the next 6 months anyways so i guess I will have to put si hubs on then so just upgrade then i guess..
Old Apr 21, 2005 | 12:01 PM
Outsane's Avatar
Default Re: (Si2See)
SI and DX calipers do not fit on HF hubs...
and SI and DX axles do not fit into HF hubs.
HF axles are like tooth picks anyhow.
just so you know
Old Apr 21, 2005 | 12:08 PM
Si2See's Avatar
Yeah thanks for the info what i will do is buy a crx si whole hub and what not and new crossdrilled and pads and i guess stock calipers from an si when i do the b16 swap just have to save a little longer or keep a lookout for the whole stock setup.
Old Apr 21, 2005 | 05:20 PM
bagpipe goatee's Avatar
this may make me sound like an ***, but i'm not meaning to. just making sure you know crossdrilled rotors are just for looks, not performance, right?
Old Apr 21, 2005 | 06:29 PM
Si2See's Avatar
no didnt know that,.... bottom line is i bought a set of Brembo cross drilled and slotted rotors with axis pads for my integra and it went from barley stopping to stopping on a dime.. thats what i want.. but if you have better input please tell me i bought the car tonight and it wont stop well enough for me.
Old Apr 21, 2005 | 07:42 PM
well, its not so much that it makes it worse, but the little they cool doesn't make up for the area lost that the pad could grab on to. and gas released isn't a problem anymore, because new pads don't really do that. so theres really no advantage to having them drilled. i hear the slotted can help with certain pads.
on your integra, your old rotors had probably overheated many times and had pad material coked on them, and your pads probably sucked, thats probalby where the major increase came from.
i'm not trying to keep you from buying them, its not like it'll make your car not stop, but to me they're not worth the extra money i'd rather invest in quality pads. make sure you don't get racing pads, though, you'll need way too much pedal pressure for around town until they heat up.
Old Apr 22, 2005 | 07:26 AM
Si2See's Avatar
ok so if you had just bought a 91 hf and plan on doing either a sohc vtec, ls or b16 swap what would you do about brakes like RIGHT NOW. it doesnt stop near as fast as i want it to when i go on road trips which i do about every weekend. but i dont want to have to change everything back over if i have to change the hubs or whatnot for a swap...
Old Apr 22, 2005 | 12:16 PM
ZeroTorque's Avatar
Ive recently just done a HF to Si brake upgrade, i had Si hubs previously and my HF calipers did bolt to them, my car doesnt seem to have much stopping power, im thinking i may have to get the Si master cylinder and prop valve to get better stoppage. but your hf calipers will not fit Si rotors
Old Apr 22, 2005 | 12:29 PM
TheSSG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si2See &raquo;</TD></TR><TR><TD CLASS="quote">ok so if you had just bought a 91 hf and plan on doing either a sohc vtec, ls or b16 swap what would you do about brakes like RIGHT NOW. it doesnt stop near as fast as i want it to when i go on road trips which i do about every weekend. but i dont want to have to change everything back over if i have to change the hubs or whatnot for a swap...</TD></TR></TABLE>
Get some blank Rotors and PBR Deluxe pads...I think that's like...$27 for the pads...and then depending on the rotors...get Autozone el cheapo ones...youcould prob be all done for &gt;$50.
Old Apr 22, 2005 | 12:45 PM
Servo's Avatar
To reiterate...
-Autozone cheap rotors (if yours are shot)
-High-quality brake pads (pick your poison, just get a decent coef. of friction and a low temp rating)
-Flush your brake fluid (Valvoline Synpower is good stuff, but I haven't verified if 4th gens are DOT 3/4 or not. My guess would be, yes.)
Old Apr 23, 2005 | 08:25 AM
Si2See's Avatar
Thanks for your help it just doesnt stop the way i want it to at all i am going to get it on a lift here at work in a few minutes and look but i am thinking about turning the rotors ( but that may have already been done ) and then throwing on some new cheap pads for now for the reason being the swap and stuff willl come within the next 4 months or so i just want to be able to stop between now and then... thanks guys
Old Apr 23, 2005 | 06:33 PM
dx front brakes are exactly the same as si ones, just get the spindles(knuckles)/rotors/calipers off a dx or si. you have to get them anyway, and it'll help. replace anything that needs it, ie rotors, pads, maybe calipers.
if you really want more than that, theres the old ex knucles (which is (i think) 10.2 inch brakes), DA (90-93 integra) ones but the geometry is off, theres also another brake thread running around now that shows 10.2 brakes with huge calipers on dx/si spindles.
https://honda-tech.com/zerothread?id=1171175
Old Apr 25, 2005 | 12:02 PM
Si2See's Avatar
yeah thats exactly what I am going to do is get the dx ones because i believe there is one in a junkyard right up the road that is untouched. I was going to buy new rotors and pads definetly. Is there anything else I should replace like the calipers what would be a good cheap but reliable option on those. And also what about brake lines etc anything else I will need I dont want to walk into this blind or without all the parts. Thanks
KhmerdudeSiR
Nov 12, 2008 07:48 PM
CRXherbie91
Nov 10, 2008 10:24 AM
xparalandrax
18
Mar 10, 2007 10:57 AM
superbeastcrx
Nov 2, 2004 07:00 AM
Serdar
11
Feb 21, 2004 11:54 AM
