anybody know wiring on passenger side of 92 prelude s?
Old Apr 21, 2005 | 04:40 AM
LSRracing95's Avatar
Default anybody know wiring on passenger side of 92 prelude s?
my friend and i were drilling through the firewall on his 1992 prelude s yesterday to install power wire for his stereo system.. while i was drilling through i believe that i through some of the main wiring in the car because i did not realize that it was so close to where i was drilling.. i found the wiring and opened up the casing that holds the wiring tightly.. it seemed as though 6 wires were disturbed.. the problems with the car are: ignition will not work (car and motor will not turn on), power windows do not work, air,a/c, heat will not even turn on, dash lights, gas guage, engine temp guage etc. will also not turn on/illuminate.. three of the wires that seem to be frayed were white and thicker than the rest of the wires, one of them was totally split and was black with green, and the other was a thin black wire.. does anyone know anything about this and could please help out! it would be very much appreciated and also can i solve this problem by just snipping all the ruined wires and soldering in new pieces of wire? PLEASE HELP!! with any knowledge or advice or ways to fix the problem, thanks a lot guys.
Old Apr 21, 2005 | 05:18 AM
Lewdin' Incognito's Avatar
Default Re: anybody know wiring on passenger side of 92 prelude s? (LSRracing95)
Why don't you just patch the broken wires? I would use crimp connectors, but soldering works too.
Old Apr 21, 2005 | 11:07 AM
Default Re: anybody know wiring on passenger side of 92 prelude s? (neoluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neoluder &raquo;</TD></TR><TR><TD CLASS="quote">??
well yeah, that is what i was planning on doing and i was going to solder and shrink wrap.. but i am also just looking into the problem futrher and trying to figure out the color combinations of the ruined wires to see which wire controls which part of the car.. i was seeing if anyone knows if the true reason the car and some of the features arent working is really because the wires are broken or if ti could be something else causing the car not to work.. as i said.. i didnt touch anything else besides drilling through the firewall and i just really feel bad for my friend because he has no car as of right now and i just want to get this problem fixed.. thanks again guys.. keep postin
Old Apr 21, 2005 | 12:46 PM
Jagan'92's Avatar
Well, I'd think one at least of the thick whites are the ignition wire, and if that's cut none of the electrics should turn on period.
Old Apr 21, 2005 | 06:25 PM
Default Re: anybody know wiring on passenger side of 92 prelude s? (Jagan'92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan’92 &raquo;</TD></TR><TR><TD CLASS="quote">Well, I'd think one at least of the thick whites are the ignition wire, and if that's cut none of the electrics should turn on period.</TD></TR></TABLE>
yeah im kinda thinkin that logic too.. im going to work on it tomorrow and just try repairing all the wires that i can tell are visibly ruined and see if that solves all the problems... anyone with any knowledge or advice about this situation keep the input coming its very useful.. thanks again guys, very much appreciated.. ill keep ya updated
Old Apr 23, 2005 | 09:36 AM
alright well im in the process of getting the wires put back together.. the system is all wired up i just have to get crimpers and connectors and im set.. ill let ya know..
cyhm
Lighting
Sep 4, 2015 04:35 PM
boosted98acura
Jan 27, 2008 02:56 PM
SlankysGirl
Nov 15, 2007 12:57 PM
GroundZer0 336
Jun 5, 2004 01:01 PM
