type-s/sh coolant drain plug lcoation?
trying to locate this on my type-s and can't find any info in the honda workshop manual either. for base model, the coolant drain plug is on the right of the oil filter (as per manual) but not on the type-s. location with pic or diagram would be great. am assuming that refil procedure will be the same ?
many thanks.
many thanks.
IIRC, it's right under the radiator. There should be a little hole and a screw/plug.
http://www.hondaautomotivepart...YO%29
Edit: the drain plug is #2.
thanks. i am aware of the radiator drain plug and should have specified the block drain plug instead. i want to clear the engine of all traces of old coolant.
camera obscura
Jul 13, 2004 06:04 PM
