Ls_vtec conversion what pistons to use?
Hi, i have a b18/b block with a b16 head, i would like to no what piston i should use if i want a compression of about 11:1 or 11.7:1 (its going to be an everyday car) also can you guys please advice what else i can do to make the car faster?
according to the c-speedracing compression calculator, the p30 (jdm b16) piston would be ideal for your compression goals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beast1 »</TD></TR><TR><TD CLASS="quote">thanx, if im not mistaken then the p30(b16) is the piston from the 1600 vtec </TD></TR></TABLE>
still will work. also what about jdm gsrs? i believe those are around 11 or so yea?
slipstream
Nov 8, 2004 01:36 PM
