Throttle Plate Sticks
Old Apr 20, 2005 | 11:29 PM
clutcher's Avatar
Default Throttle Plate Sticks
Hello all,
How do I fix a sticking throttle plate? Couple days ago I took out the whole intake manifold including the throttle body and cleaned both thouroughly with carb cleaner.
The throttle plate was sticking before I cleaned it. It's still sticking though--even though it's a little bit less. How do I fix it? Would sanding with a high grit paper (say close to 1000) even out any irregularities that make it stick?
Thanks!
Old Apr 20, 2005 | 11:31 PM
SOHC4life 96's Avatar
Default Re: Throttle Plate Sticks (clutcher)
It could be your throttle cable that is sticking. Over time grease and dirt will accumulate inside of it and cause it to get stiff. But I wouldnt take sand paper to the inside of your throttle body. That is something for the pros to mess with.
Old Apr 20, 2005 | 11:47 PM
clutcher's Avatar
I appreciate your reply but if I wasn't sure what it was, I was going to ask what it could be.
It's the throttle plate sticking to the throttle body wall.
Question is, how do I fix it without damage?
Thanks!
Old Apr 21, 2005 | 01:46 AM
boostinhatch's Avatar
^ no longer owns a honda
Default Re: (clutcher)
I had that problem on my edelbrock tb, look up under the "wheel" that your throttle cable hooks to and there should be a screw/bolt that the wheel sits on when the throttle is closed. You need to back it out just a tad so that it wont let the throttle plate close so far
Old Apr 21, 2005 | 04:59 PM
clutcher's Avatar
That screw thingy fixed it!
Maybe this should be added to the FAQ since when I was searching I didn't see anyone mention this little screw/bolt thingy and most people were sanding their throttle bodies and having idle problems afterwards.
Thanks boostinhatch!
John
Old Apr 21, 2005 | 05:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clutcher &raquo;</TD></TR><TR><TD CLASS="quote">That screw thingy fixed it!
John</TD></TR></TABLE>
no problem, you may have to put a little loc tite in it to hold it in place( had to do mine, because turbo and solid mounts and all kinds of other good things cause lots of vibration)
Tippyman
Jul 27, 2013 10:20 AM
Cpt Ben
Apr 5, 2007 07:18 PM
monkalotamus
Nov 15, 2006 06:31 PM
ic108
Jan 28, 2002 10:24 PM
Top
Follow Us
