unhooking ac belt
Old Apr 20, 2005 | 09:05 PM
seeeya04's Avatar
Default unhooking ac belt
Taking my ac belt off wont do anything right ..
just wanting to take some of the load off my motor.
Old Apr 20, 2005 | 09:36 PM
parasonic's Avatar
Default Re: unhooking ac belt (seeeya04)
I know that it won't do much. From my understanding, there will be a few moving parts, maybe as much as a flywheel that you can save energy by not moving. The AC is engaged by a clutch system.
Old Apr 20, 2005 | 09:37 PM
parasonic's Avatar
Default Re: unhooking ac belt (parasonic)
By the way, if you're going to disconnect your AC, are you ever going to use it again? You might consider removing it to save weight, even if you're doing this for daily driving. Less mass means better MPG especially in stop and go traffic.
Old Apr 20, 2005 | 09:40 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
the only good taking off the AC belt, is to reduce drag of 1 sealed bearing. its not worth it..
the only reason "racers" remove AC, is for weight, and never wants that drag of HP. the engine turning over 1 tiny sealed bearing isn't going to make a differance. the only HP robbing factor would be if you race wtih the AC on.. and thats a no brainer.
Old Apr 20, 2005 | 09:42 PM
VRD^sam's Avatar
Default Re: unhooking ac belt (Built B16A)
you get more ponypower...
Old Apr 21, 2005 | 12:21 AM
hatch34's Avatar
Default Re: unhooking ac belt (ef9turbohatch)
i have seen on a dyno chart that pullin the AC belt can add up to 5 whp in the mid range and the same goes for the PS it does make a diff
Old Apr 21, 2005 | 12:27 AM
si_lee's Avatar
if your gunna remove the a/c to reduce weight, you should remove everything including the compressor and condensor and the hoses since the system will be useless.
Old Apr 21, 2005 | 04:48 AM
parasonic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9turbohatch &raquo;</TD></TR><TR><TD CLASS="quote">you get more ponypower... </TD></TR></TABLE>LOLLERSKATERS!!1
tatsu022182
Honda Civic (2001 - 2005)
Mar 19, 2018 10:27 PM
markysparky
21
Oct 30, 2005 08:03 PM
ophdehEEzY
May 6, 2003 09:08 AM
Spartanic
Mar 29, 2002 08:19 PM
