what throttle body will bolt right up to jd edelbrock victor x
Old Apr 20, 2005 | 08:48 PM
ssr_h22's Avatar
Default what throttle body will bolt right up to jd edelbrock victor x
im gettin a jg edelbrock victor x. im going boost. trying to hit 500whp. i want to get a bigger throttle body. which one is good bbk 70mm or str 70mm. i want something that will bolt right up. no big modification. i searched some and didnt really find much. let me know.
Old Apr 20, 2005 | 09:08 PM
mrDFWmechanic's Avatar
those str tb's will bolt up just fine, only thing you might need to modify is the tb gasket.
Old Apr 21, 2005 | 12:49 PM
ssr_h22's Avatar
anyone use bbk 70mm
Old Apr 21, 2005 | 12:50 PM
dustin's Avatar
Default Re: what throttle body will bolt right up to jd edelbrock victor x (ssr_h22)
Why do you want a bigger throttle body?
Old Apr 21, 2005 | 01:59 PM
MrBui's Avatar
i used a stock throttle body but bored out
Old Apr 21, 2005 | 02:08 PM
Default Re: what throttle body will bolt right up to jd edelbrock victor x (MrBui)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrBui &raquo;</TD></TR><TR><TD CLASS="quote">i used a stock throttle body but bored out </TD></TR></TABLE>
you could do that too, send your tb to maxbore thats what i'm gonna do to my gsr
Old Apr 21, 2005 | 02:13 PM
dustin's Avatar
What's wrong with the factory throttle body? The turbo is creating positive pressure.. the intake manifold sees the same amount of pressure as the piping before the TB. These aren't naturally aspirated cars...
Old Apr 21, 2005 | 02:14 PM
so having the tb bored out doesn't really do **** then ?
Old Apr 21, 2005 | 02:15 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: what throttle body will bolt right up to jd edelbrock victor x (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">What's wrong with the factory throttle body? The turbo is creating positive pressure.. the intake manifold sees the same amount of pressure as the piping before the TB. These aren't naturally aspirated cars...</TD></TR></TABLE>
cotney made 800whp on stock tb. If you do get a tb STR is no longer around, its now http://www.bdlind.com (BDL).
art
Old Apr 21, 2005 | 02:17 PM
dustin's Avatar
Default Re: (iROCKtheSOHC)
Well it adds an additional item to your mod list...
And cars with bored out TBs etc seem to have lots of idle problems and stuff... so it can "do ****"... just not anything beneficial. Just one more thing that can break / mess up.
Old Apr 21, 2005 | 03:20 PM
but what if you have a big intake manifold like the victor X you'd need a larger mm tb to fit it properly correct ? it wouldn't be smart to use an oem gsr on a victor X, or am i wrong by saying that
Modified by iROCKtheSOHC at 5:10 PM 4/21/2005
Old Apr 22, 2005 | 09:52 AM
Marauder's Avatar
There's no reason to go any larger than your charge pipe diameter.
Did a test of that on a civic, with an edelbrock turbo kit. The charge pipe diameter is about the same as the stock 56mm of the civic throttle body. Putting on a 62mm throttle body did nothing to the power output.
Old Apr 22, 2005 | 10:14 AM
PM-Performance's Avatar
stock ITR TB is 3inches.
Worked great for me.
BTW i had it on a JG also
Old Apr 22, 2005 | 11:26 AM
hmmmm interesting.
Old Apr 22, 2005 | 01:25 PM
ssr_h22's Avatar
so my stock gsr throttle body will bolt right up to the victor x
Old Apr 22, 2005 | 01:39 PM
MrBui's Avatar
Default Re: (ssr_h22)
yes it will bolt up
Old Apr 22, 2005 | 04:00 PM
N20civicB18's Avatar
Default Re: (MrBui)
d16 one will bolt right up
Old Apr 22, 2005 | 05:25 PM
h22 civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC &raquo;</TD></TR><TR><TD CLASS="quote">those str tb's will bolt up just fine, only thing you might need to modify is the tb gasket. </TD></TR></TABLE>
what exactlly you do to the t/b gasket ?
Old Apr 23, 2005 | 05:31 AM
Default Re: (h22 civic)
make the bore of the throttle opening slightly larger so the butterfly can open through it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">
what exactlly you do to the t/b gasket ?</TD></TR></TABLE>
Old Apr 23, 2005 | 06:56 AM
h22 civic's Avatar
Default Re: (N20civicB18)
did it interfear with any of the other ports on the t/b gasket when you ported it how big did you go asking cause im about 75 mm on my gasket now and im having to cut into some of the ports on the gasket wich mite cause a vac leak
Old Apr 23, 2005 | 07:53 AM
Maverik4k's Avatar
U also have to think how big your intercooler piping is, because thats will you will lose power going from a 2.25in pipe to 70mm which i think is like 2.5in maybie a little more?
i ported matched my aebs intake manifold and put a str(70) to it, the throttle responce was nicer and i gained like 5hp but thats on stock block b16 turbo.
civicd15b
Mar 10, 2011 08:11 AM
Nicks95GSR
Aug 9, 2007 09:56 PM
k24a4kid
Aug 4, 2006 06:43 PM
vietboiracer0
Dec 13, 2005 12:19 PM
Fink2iCe
Aug 20, 2004 10:50 AM
