Serius help needed, car Started smoking...
Old Apr 20, 2005 | 07:21 PM
teamner's Avatar
Default Serius help needed, car Started smoking...
ok ok, i got my 1990 hatch running with a new zc sohc swap and replaced the head gasket and got all wiring done, but, i took out for a spin, and its only firing on two cylinders, dnt kno why, and plus the botom of my car started smoking up like it wanted to catch on fire, i have no clue what the heck happened, the whole interior floor of the car is hot, the backseats are hot, and it smells like burnt in there, what could have happened, thanks for any feedback.
Old Apr 20, 2005 | 08:16 PM
ServiceAdvisor's Avatar
Sounds like a clogged cat. - Darrell
Old Apr 20, 2005 | 09:20 PM
J-Civic SIR's Avatar
Default Re: Serius help needed, car Started smoking... (teamner)
Make sure that you re check all of your stuff, and make sure that you didn't miss anything, or hook up anything wrong. as for that two cyl. problem the first thing that I would check is your ign. and see if you might have hooked it up wrong. It could be a cloged cat. but that would make no sense if it worked before. Unless you scewed it up well you were doing the swap. anyways hope it works out for you.
Old Apr 20, 2005 | 09:32 PM
RCautoworks's Avatar
Default Re: Serius help needed, car Started smoking... (J-Civic SIR)
Since you replaced your head gasket I'm assuming the old one went bad. If so, if coolant ever touched your 02 sensor you need to replace it, the same rule also applys for cats but rarely anyone will replace a cat after a headgasket. Some people won't even get a new head gasket either.
Old Apr 20, 2005 | 09:49 PM
teamner's Avatar
well its just odd that this happened, i also heard this weird backfiring sounds near the cat while i was driving it around corner, sort of like if it was loose and compression was just too much and air was escaping. Quuick, question though, if it was a clogged cat, why did my whoile car smell like burnt inside and all of the bottom of my car, completely was smoking when i lifted it the front with a jack??anyone know?? i seriusly need help with this its driving me nuts not having a car. thanks for any help.
Old Apr 21, 2005 | 09:24 AM
Default Re: (teamner)
Did it smell like coolant ? I mean how bad was the old head gasket ? Did a lot of coolant get in the exhaust ? It could of been the coolant burning off. If its stuck inside your cat and thats where its burning at, right around there , there is a hole for the shifter to come threw the floor. So it could of got in that way
Old Apr 22, 2005 | 01:42 PM
teamner's Avatar
the head gasket was not so bad, part of it was ripped appart by the piston barrels on both sides by the dizzy side and on the opposite side. i just gave up on my zc sohc engine and am thinking of just pulling it out and starting fresh with an si engine. let me know what you guys think.
AddiXz
Nov 3, 2013 06:02 AM
civic_jones
Aug 25, 2008 01:57 PM
pandacivicsi92
Apr 2, 2008 12:42 AM
weemanch
Jan 14, 2008 11:26 AM
civic dx
Sep 24, 2003 07:13 PM
