Short Shifter Install
Old Apr 20, 2005 | 06:16 PM
SIcivicHATCH's Avatar
Default Short Shifter Install
searched...
anyone know how to take out the stock shifter on a crx?? I got the bolt off the shifter to the shift linkage now i cant get the ball out of the joint.
Old Apr 20, 2005 | 06:17 PM
Bjorn20's Avatar
Default Re: Short Shifter Install (SIcivicHATCH)
ive wondered the same thing, since i eventually want a short shifter
Old Apr 20, 2005 | 06:20 PM
Default Re: Short Shifter Install (Bjorn20)
bump we are working on it now
Old Apr 20, 2005 | 06:30 PM
bump....
Old Apr 20, 2005 | 07:15 PM
GreenMachineRex's Avatar
there is a dust sheild. 2 ---- 12 MM bolts. pry that off and pull down. also unbolt it from the tranny. its madd easy
Old Apr 20, 2005 | 07:47 PM
1988c-rex's Avatar
Default Re: Short Shifter Install (GreenMachineRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex &raquo;</TD></TR><TR><TD CLASS="quote">there is a dust sheild. 2 ---- 12 MM bolts. pry that off and pull down. also unbolt it from the tranny. its madd easy</TD></TR></TABLE> thats all you need to do, way easier than i thought it would be and didn't take that long to do.. good luck with it
Old May 4, 2005 | 10:24 AM
Bjorn20's Avatar
with that said.. would a noobie like me still **** it up, or could i do it myself?
well is there anything that u can majorly screw up if u do it wrong.. only thing id guess is u couldnt change gears cause the shifter wouldnt work.
i read on about tranmsissions and such on howstuffworks.com and i learned what a dust shield was!!! go me, i actually know wtf u guys are talking about now
Old May 4, 2005 | 10:49 AM
urbansi's Avatar
i got a short shifter that i am looking to get rid of, never used, in origional package. you want one. its off of ebay.
Old May 4, 2005 | 11:07 AM
2kTeg's Avatar
Default Re: Short Shifter Install (urbansi)
just climb under your car take out the bolt that goes threw the shifter and then take out the two 12mm bolts that hold that up drop the whole thing down and pull your old shifter out.
Old May 4, 2005 | 12:59 PM
Bjorn20's Avatar
Default Re: Short Shifter Install (2kTeg)
ill see what i can do, im a noob at work
Old May 4, 2005 | 01:00 PM
Bjorn20's Avatar
hell ill take it, what kind of shifter so i know what to search for
Old May 4, 2005 | 01:14 PM
sohc hatch's Avatar
Here a picture I had in my folder. Hope it helps out.
Good Day,
RH.
Edit: Picture was removed.
Modified by egturbohatchback at 4:32 PM 5/4/2005
Old May 4, 2005 | 01:34 PM
Bjorn20's Avatar
Default Re: Short Shifter Install (egturbohatchback)
woa... never seen that there before.. probly because all the cars ive looked at they were all autos and arent supposed to have that. but eh doesnt look too tricky
thx for pic
long time ago i thought all u had to do was take the shifter out from the inside of ur car, and put a new one back for a short shifter... but i was retarded, and less retarded now and didnt know exactly what a short shifter was.
Old May 4, 2005 | 01:39 PM
sohc hatch's Avatar
The silver looking pipe is the exhaust and the other pipe is the shift linkage which is what the shifter is attached too.
I'll keep the picture up for a bit so save it for reference.
Good Luck !
Good Day,
RH.
Old May 4, 2005 | 02:43 PM
Bjorn20's Avatar
ya thx, ill need it lol
Old May 14, 2005 | 10:02 PM
up's Avatar
up
Does anyone have the picture saved? I just searched for this thread, and the picture isn't up anymore. Thank you for your help.
Old May 14, 2005 | 10:11 PM
hahagasdcrx's Avatar
Default Re: Short Shifter Install (up)
(topside)
Remove shift ****.
(under car)
Unbolt the 12mm bolt that goes through the shifter.
Then unbolt the 2 12mm bolts on the back, holding the stabilizer rod to the body.
Drop the linkage down and undo the 2 10mm nuts on the bottom of the shifter.
Pull the plate off and take out the shifter.
You can also unbolt the whole stabilizer rod from the tranny, that way you dont have to do all this **** while under the car.
To install , do all this in reverse.
mackhaio5
Mar 12, 2006 05:24 AM
superbeastcrx
Sep 13, 2005 06:09 AM
92BluEH-3
Jun 20, 2005 06:10 PM
mcaro
Jun 21, 2004 07:13 PM
phreaker
Nov 7, 2002 08:46 PM
