Does sedan EG suspension work on a hatch EG?
Old Apr 20, 2005 | 05:53 PM
rasinhell's Avatar
Default Does sedan EG suspension work on a hatch EG?
Hey guys my shocks are all blown and i'm looking to find some temporary stock suspension for now. There is a guy selling all 4 for 40 bucks but its' from a sedan, do you guys know if this will work on my Hatch?
His is a 95 sedan mine is 92 hatch
Old Apr 20, 2005 | 05:57 PM
Deemeetree's Avatar
Electrician
Yes, 1992-1995 suspension is interchangeable whether or not you have a hatch, sedan, or coupe.
Old Apr 20, 2005 | 06:58 PM
lifendet's Avatar
interchangeable
Old Apr 20, 2005 | 07:14 PM
rasinhell's Avatar
Default Re: Does sedan EG suspension work on a hatch EG? (The-Beast)
Cool, thanks for the info!
Is the sedan suspension higher then the hatch si at all?
Old Apr 20, 2005 | 07:22 PM
civictildeath's Avatar
spring rates are different though.
keep your springs and use the other's shocks and you will be just like new
https://honda-tech.com/zero...age=4
Old Apr 20, 2005 | 08:26 PM
IS3Fifty's Avatar
Default Re: Does sedan EG suspension work on a hatch EG? (civictildeath)
do you have a set laying around or are you planning on buying a stock eg suspension?
Old Apr 20, 2005 | 11:05 PM
rasinhell's Avatar
Default Re: Does sedan EG suspension work on a hatch EG? (Bar'dEK)
Well right now i have billstien shocks that are blown. on some cheap coilovers.
Theres a guy that has stock suspension of an Sedan and he's selling it for 40... so yeah, i dont have the springs..
Would I be able to use the coilover sleeves on the stock suspension and just not lower it so much? Like lower it 1 inch?
So let me get something straight, the spring rates differr but height is the same?
thanx
Old Apr 26, 2005 | 02:30 PM
rasinhell's Avatar
If the spring rates are different on the sedan, does that mean the car will be higher then normal?
Old Apr 26, 2005 | 03:03 PM
doughboy_88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Beast &raquo;</TD></TR><TR><TD CLASS="quote">If the spring rates are different on the sedan, does that mean the car will be higher then normal?</TD></TR></TABLE>
ride height might be affected simply b/c the springs don't compress as much if your hatch is lighter than the sedan. what's equally important is that handling characteristics are also affected with the new spring rates.
in the event that the strut/spring combo is mismatched, you might get an over/under-dampened setup.
Old Apr 26, 2005 | 04:08 PM
GarettBrowning's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Yes, 1992-1995 suspension is interchangeable whether or not you have a hatch, sedan, or coupe.</TD></TR></TABLE>
GabeEgHatch
Suspension & Brakes
Jul 25, 2013 02:29 AM
jorgenov30
May 30, 2011 10:58 PM
Show15
Suspension & Brakes
Jan 24, 2010 06:55 PM
JDMsil80
Nov 3, 2006 02:42 PM
