how many trannies have you broke??
Old Apr 20, 2005 | 05:46 PM
ihateslowhondas's Avatar
Default how many trannies have you broke??
i just blew up my 3rd transmission in my crx within the year and a half i have owned it.this is kinda funny , heres my list of tranny and cause of death.
#1 dx 5 speed, it basically threw the spider through the case durring a high rpm holeshot. the engine was a d15b2 mpfi swapped and 230,000 miles
#2 89 si tranny, broke 2 shift forks and the surprizing thing is i drove it for a month like that. one day at a gas station it failed to go into reverse so i swapped it out. this was with jdm d15b vtec.
#3 last monday night i was hitting some turns and the last time i went for 3rd it just wouldnt go in, i finally got it to go into 3rd hit 4th slowed to a stopsign and when i took off i tried for second and she was gone. managed to get it home by doing a u turn in 3rd uphill and rolled through a few intersections, whined like an sob the whole way. just another si tranny..........
my project as of now is to assemble #2 with shift forks from #1 , haha. i work at a tranny shop so i might as well do new seals too. tell me some effed up trannies you have.
Old Apr 20, 2005 | 05:50 PM
crxgator's Avatar
Default Re: how many trannies have you broke?? (ihateslowhondas)
Old Apr 20, 2005 | 05:52 PM
CRX_Control's Avatar
you got tranny issues big time , im still on my 1st tranny ,well if you look at it as me swaping an engine with another transmision , then i guess thats two ,but i havent broken one yet .
Old Apr 20, 2005 | 05:55 PM
they were all old, like 200k and i drive it with no mercy. its just a honda...... and i also never grind one gear ever
Old Apr 20, 2005 | 06:21 PM
EP3_05's Avatar
b16a+j1 trans+sticky tires+wheel hop=kaboom
That was more than three years ago. I am on my second J1 trans and it has held up since then.
Old Apr 20, 2005 | 06:23 PM
kulangot's Avatar
Default Re: (ihateslowhondas)
Old Apr 20, 2005 | 06:46 PM
how much stronger is b series, could i even possibly with all my mite break forks in those?all my synchronizer rings and clutching teath on the gears still looked good. i was thinking of a b18 swap to boost for a laugh but only if i get it for free or cheap , honda was only worth modifying back in my younger days.
Old Apr 20, 2005 | 06:48 PM
crx_of_fury's Avatar
i broke of a shift fork on my first si tranny while i stomped on it to pass a car on the highway. i pulled it out and took it apart to see what broke and i only had a couple capfulls of fluid in there. if i was you i would really look into getting a zc tranny, they are a lot lower geard and make a sohc haul ***. they really seem to be stronger to. i put mine through hell and it works good. i use the zc with stock axels with 86 accord shafts to make them fit with a 86 accord clutch and a crx pressure plate. i love it. thanks
Old Apr 20, 2005 | 06:56 PM
omg wtf r u talking about... stock zc is effin reatarted and long geared.... i would use a zc with an si final drive if i wanted to spend$$$$ on a zc tranny but untill i find one for like 50 bucks im going to hold offf on it. the zc is stronger but more like a dx tranny with stock fd . hondas are just fun to **** up theyre a dime a dozen lol
Old Apr 20, 2005 | 07:11 PM
ukdm crx's Avatar
0 for me, sounds like you need to learn how to drive.
Old Apr 20, 2005 | 07:13 PM
ServiceAdvisor's Avatar
Si trans = 2 1 89 and 1 91
DX trans = 2 1 88 and 1 90
HF trans = 1 Just because I could, unknown year.
Two Si's and 1 DX were broken because of a faulty differential pin caused by previously using the wrong axels on my part. The axel ends were rubbing it and forcing it to heat up and eventually a strong shift would cause it to snap. Mind you, this is one little solid piece of material and it would be thrown all over the casing and destroy trans. But yeah, I'm good at destroying trans, and I don't really race uzzled: . - Darrell
Old Apr 20, 2005 | 07:20 PM
i guaranteee i can run my car at any kind of course better than 95% of anyone on here so dont tell me i need to learn how to drive. **** breaks when you push it too far esspecially when its older than dirt and had who knows what done to it in the past. i care about my crx so much i let girls borrow it all the time without thinking twice. i have 50 bucks in 3 trannies , its funny when they go.
SkaiWu
Nov 6, 2008 09:53 AM
SlAmMeD 91 HaTcH
14
Nov 8, 2005 09:28 AM
julio_bOostamante
Aug 27, 2005 09:00 AM
kriptik
May 27, 2005 10:15 AM
nuc79
Oct 4, 2003 04:16 PM
