Do I have to break in a air compressor
Old Apr 20, 2005 | 02:27 PM
HONDAAREFORME's Avatar
Default Do I have to break in a air compressor
I recently brought a air compressor its a 5hp 30gall 150psi max craftsmen and someone told me that i have to break it in before I use it and I was wondering is this true and how thank.
Old Apr 20, 2005 | 02:28 PM
It brand new.
Old Apr 20, 2005 | 02:30 PM
Malgerus's Avatar
Default Re: (HONDAAREFORME)
Don't know about that, but we used ours right away, no break in time or anything...
Old Apr 20, 2005 | 02:33 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
from what i remember you have to run the compressor with no load (the bleed nipple open) for about 20-30min, then fill it up and use it, make sure to drain the tank everyday.
the instructions provided should note the procedure.
stan
Old Apr 20, 2005 | 02:34 PM
Mach69's Avatar
Default Re: Do I have to break in a air compressor (HONDAAREFORME)
You know this is a car forum, right? But your thread will be locked because it is not a car tech related.
I remember when I used to work at pep boys our air compressor had to be drained each day as well.
Old Apr 20, 2005 | 02:46 PM
oldSCHOOLhonda's Avatar
says right in the instructions, i got the same one run w/ bottom water **** open for 10 min...there's a whole precedure to follow
Old Apr 20, 2005 | 03:08 PM
RCautoworks's Avatar
Default Re: (Stan D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D &raquo;</TD></TR><TR><TD CLASS="quote">from what i remember you have to run the compressor with no load (the bleed nipple open) for about 20-30min, then fill it up and use it, make sure to drain the tank everyday.
stan</TD></TR></TABLE>
Your right, but its 15mins.
Old Apr 20, 2005 | 03:11 PM
LSvtec03's Avatar
Default Re: Do I have to break in a air compressor (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">You know this is a car forum, right? But your thread will be locked because it is not a car tech related. </TD></TR></TABLE>
although crx forum may not be the best choice, last time i checked, people use air compressors on cars.
Old Apr 21, 2005 | 02:17 PM
Thaks for info
Just to be safe im going to ran it for 30mins, better safe than sorry
Old Apr 21, 2005 | 02:18 PM
I was just wondering how long till i can post in the all the areas
Old Apr 21, 2005 | 02:19 PM
sorry for this thread
sykikchimp
12
Jun 9, 2010 04:03 AM
Propulsion
Welding / Fabrication
Nov 16, 2005 06:14 AM
dabrown
Mar 15, 2004 09:01 AM
BARF1
Aug 16, 2002 04:03 PM
