Coolant Leak...Where?
Old Apr 20, 2005 | 01:34 PM
NorcalHB94's Avatar
Default Coolant Leak...Where?
ok with my old d15b7 motor i had an existing coolant leak from the radiator itself...would have to refill maybe every week.
Just swapped in jdm d15b and now by the end of the day it's overheating and there's coolant all over the passenger side of the engine bay...and i can't find where it's coming from.
couple pics for reference -
these hoses had a small ring of coolant sitting:
picture of what the coolant is getting all over:
any help?
Old Apr 20, 2005 | 01:40 PM
RCautoworks's Avatar
Default Re: Coolant Leak...Where? (NorcalHB94)
The first 2 hoses in the first pic are trans coolant lines, antifreeze does not run threw them.
I would say start the car, let pressure build up and look around for the leak
Old Apr 20, 2005 | 01:42 PM
Cuong-nutz's Avatar
Are your radiator hoses new and clamped down snug? Might also check the overflow. Bleed the coolant system and check to see if the radiator cap is still good.
Old Apr 20, 2005 | 03:56 PM
NorcalHB94's Avatar
Default Re: Coolant Leak...Where? (Cuong-nutz)
ok, i filled the coolant back up and started the car and let it warm up...(radiator fan never kicked in)
that's the hose going directly to the front of the motor, it looks to be clamped on all the way but it's still dripping, and leaving quite a small neat little puddle on the ground. could the hose just be bad? should i replace it?
Old Apr 20, 2005 | 04:33 PM
Of course replace it, probably a hole in it
Old Apr 20, 2005 | 04:39 PM
deSigi's Avatar
Default Re: Coolant Leak...Where? (90blackcrx)
Make sure the clamp is still good. It might not be keeping the hose in place tight enough. Get a new hose for sure though.
Old Apr 20, 2005 | 05:49 PM
turbo_b16_ex's Avatar
if its a small spray, you have a small crack or puncture. they do that i guess cuz of wokring on them or motor flex. when ur car heats up and gets pressure, start bending the hoses around in the area of the leak and you should be able to find it. My cars done this PLENTY of times
Old Apr 22, 2005 | 07:13 AM
Phoenix Fire's Avatar
Go buy some new radiator hose, I would replace both hose. Drain coolant, replace hose. Fill coolant back up, bleed coolant. Check for leaks. Your good to go!
Old Apr 22, 2005 | 07:21 AM
EJ1 wilcox's Avatar
Default Re: Coolant Leak...Where? (Phoenix Fire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phoenix Fire &raquo;</TD></TR><TR><TD CLASS="quote">Go buy some new radiator hose, I would replace both hose. Drain coolant, replace hose. Fill coolant back up, bleed coolant. Check for leaks. Your good to go! </TD></TR></TABLE>
Word, that's about the easiest hose to replace on the whole engine... and it only costs a few bucks!
I just replaced all my hoses when I changed my head gasket, a few of them were looking old and worn... some times it's hard to see a pinhole in the hose, so just replace it and call it a day...
Old Apr 22, 2005 | 09:05 AM
NorcalHB94's Avatar
Default Re: Coolant Leak...Where? (EJ1 wilcox)
yeah i drove the car around a bit and when i got back home, popped the hood...car was warmed up but not too hot and the hose was spraying out small bits of coolant every few seconds...so i'm sure that's where the massive leak is coming from once it gets really hot.
so i'll replace that hose, and i have a new radiator on the way stupid question time though, when i loosen the screw to bleed the coolant, is there visible signs to look for...will there be air bubbles or something? or just loosen it and let it sit for a few seconds and then tighten? thanks.
*edit* spelling
Old Apr 22, 2005 | 10:09 AM
alotawatts's Avatar
Looks like a worn out old original clamp to me ? Get bolt clamps. To bleed check for no bubbles. Use a long funnel if you can so that the fill level going in is higher than any other point of the cooling system...e.g. manifold sensors etc.
Gravity rules
Old Apr 22, 2005 | 10:38 AM
JdmLub's Avatar
Default Re: Coolant Leak...Where? (alotawatts)
new clamp new hose....bad to get junk on distributor(think how u spell )
Old Apr 22, 2005 | 10:49 AM
AmginE's Avatar
Default Re: Coolant Leak...Where? (JdmLub)
replace the hose, and while you're at it, flush the coolant and replace all those hoses.. that's what i do when i have a leak. (did that wednsday)
Old Apr 22, 2005 | 11:36 AM
To bleed the coolant. open up the bleeder and what until there is coolant flowing out of it with no bubbles. Good steady stream of coolant will start to flow out. Tighten bleeder up! Refill coolant reserve and radiator! Go to go!
raju687
Sep 16, 2011 05:42 PM
SeanK325
Jun 22, 2010 02:52 PM
tigueremalo
Jul 10, 2006 07:16 PM
AllMotorDA9
Oct 27, 2005 03:49 PM
Accorddrver
Jun 29, 2004 06:25 PM
