car doesnt start. did 1 hour before
Old Apr 20, 2005 | 10:59 AM
juanb's Avatar
Default car doesnt start. did 1 hour before
heres the story...
I bought a new exhaust manifold and starter and got home to install them.. i disconnect (+) and (-) battery terminals, jack the car up.
I then install my new manifold bolt everything up and change my oil. then i decide i dont want t0 do the starter so i just leave it alone. drop the car add oil and go to start the car. car doesnt start, it seems like it has a dead battery. Hestiate's to turn over, then i try again hesitate's then starts? wtf?
I drive it around runs perfect, come home shut it off and hesitates again? im confussed, it just starts up when it wants to. anything to check for? i cleaned both terminals, grounds, battery is at 12.1 volts? any ideas?
thanks
Old Apr 20, 2005 | 12:56 PM
juanb's Avatar
Default Re: car doesnt start. did 1 hour before (juanb)
bump need help!
Old Apr 20, 2005 | 01:00 PM
kleanlscivic's Avatar
check ur ground wires, and if not that try running another ground wire from the started to the frame somewhere
Old Apr 20, 2005 | 01:05 PM
flood's Avatar
Default Re: car doesnt start. did 1 hour before (kleanlscivic)
set the clock back 1 hr
Old Apr 20, 2005 | 01:19 PM
juanb's Avatar
Default Re: car doesnt start. did 1 hour before (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">set the clock back 1 hr</TD></TR></TABLE>
oh.. thanks for the advise **** head
Old Apr 20, 2005 | 01:22 PM
juanb's Avatar
ok now.. battery volts is 12.6, i checked the volts for the starter when i go to start it and they are 11.6.. can anyone think of anything else? i check my grounds, and i tried running another ground and power wire to the starter.. same ****
Old Apr 20, 2005 | 01:31 PM
flood's Avatar
sounds like a bad battery cable. What year is your car?
Old Apr 20, 2005 | 02:23 PM
juanb's Avatar
its a 99 civic si with a 00 itr motor.. now my when i go to turn the key to the on postion nothing happends.. the main relay doesnt even click!!
Old Apr 20, 2005 | 03:25 PM
TallAssFilipino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanb &raquo;</TD></TR><TR><TD CLASS="quote">heres the story...
thanks </TD></TR></TABLE>
You said you decided not to replace the starter to the new one you bought. So, you're still using the old starter? And what was the problem with the old starter?
If that is the old starter you're using and having problems with, then as you said, it starts, then an hour later it doesn't. The problem may not be the starter itself, but may be the starter solenoid. It's probably bad now. If it starts when it's cold, and doesn't start an hour later when it's hot, it could be that the coils inside are expanding as it gets hot. So it's having problems spinning.
I don't understand how all of a sudden it would be bad ground. It's grounded through the tranny. There is no actual ground wire connected to it. You can test if it spins strong by creating a jumper lead from the battery's positive termal to the starter wire input. Just pull the small female connector off the starter solenoid. Make sure it's not in gear.
Modified by MDJ IKNJ at 4:35 PM 4/20/2005
Modified by MDJ IKNJ at 4:36 PM 4/20/2005
Old Apr 20, 2005 | 03:27 PM
Mario.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanb &raquo;</TD></TR><TR><TD CLASS="quote">its a 99 civic si with a 00 itr motor.. now my when i go to turn the key to the on postion nothing happends.. the main relay doesnt even click!!</TD></TR></TABLE>
I had a problem similar to this, and if I recall it was 99.9% a bad ground.
Old Apr 20, 2005 | 04:04 PM
juanb's Avatar
i was using a friends starter thats why i was replacing it
sixfourkiller
Jun 17, 2009 10:05 AM
oc_civic
Apr 10, 2008 06:33 PM
Ph0eNix
Dec 15, 2005 11:58 AM
jerm001
17
Apr 21, 2004 07:55 PM
ILOVEGIRLS
Sep 5, 2003 12:03 AM
